Morons!
The B-position lift points (Is that right? Aren't the B point right behind the doors?) are pretty dang close to being the balance point of the car front-to-back. If that's where they put the rear lift plates, then as soon as they took the front wheels off....
Even after all your efforts at communucating the issue. Simply amazing! Hope they buy you a new one! They durn well should!
xtn
