Originally Posted by PhlypSide
You don't have to drive a car 10/10ths, or h#ll even drive it on a track to be able to thoroughly appreciate the not-so-subtle differences between the 3 ( technically 5 commonly available) drivetrain layouts. You can do this on the streets on your every day commute ( although I don't recommend breaking any applicable traffic laws/ordinances in the process).
You must not understand cars and physics much--you obviously CANNOT grasp the point I am saying. Lets make it elementary grade simple:
The power goes to the ground thru the drive wheels/rubber only, so simple driving that is not on the edge of the performance envelope will not uncover the obvious drive wheels that are working! So does a RWD car shift its weight back when launched and a FWD not--of course not.
Now, the suspension is what will control the handling of the car when moved from a steady state--this can be tweaked by the designers/engineers to do whatever you want with it. No car can be set-up for all conditions at once.
You obviously think you can easily tell if you are driving, for example, a RWD A4 versus an AWD A4 down the freeway, cause you are so smart and understand instantly the nuances of how the power is getting to the ground. Yeah, big deal--if you do such rash maneuvers, like any real driver wouldn't do, then you can coax the answer out of the car -- but my original question does not imply you drive it like a rental to get the answer, but rather that you cannot easily tell what tires are putting the power down.
Next, you are going to tell me that you drift your Subaru and can feel the differentials shifting the power between the wheels and know just when certain tires are getting the power to the road . . . .
Do you not understand that you can set-up the handling of any car to over- or understeer. Well I know this is true--just as plain as you think you know that all RWD cars oversteer and all FWD cars understeer--but I certainly do not have the knowledge/experience to tell you exactly how to set-up your car to prove it--but I can try if you want.
Do yo know there was an S1 Elise? Do you know it was prone to snap oversteer on the edge? Do you know the new Elise (probably the only Lotus you have ever known) is not prone to this like the old one? Do you think this is because they changed the drive wheels? Yes, you do.
