Old 02-28-2007, 09:38 PM   #65 (permalink)
ekological
ekological's Avatar
Images: 13
Hi Matt,
When I receive my kit from my supplier, it actually starts off very similar to my competitor's in that you get a 9006 connector with wire leads that terminate to 1/4" metal spade terminals. I cut off the terminals and fabricate my own harness using the factory connectors such that you simply disconnect the factory connectors in your car and plug mine in between. My kit comes with a metal bracket that you can mount to the car using the supplied expanding plastic rivets or you can use the included double-sided tape. My ballast has the ignitor built in so there is one less thing to dangle around. The pair of ballasts weigh about a pound in total more than the slimline ballasts. The higher output of the 50watt ballasts provide 800 more lumens per bulb.
I also notice that you're in NJ. If you're not handy, I can install the lights for you. I'm in Monroe, NJ.
HTH,
Chester
Originally Posted by mchristian
EKO, in what way is your kit different than the Sector111 package? They are both priced very close.
Custom Plug-N-Play Elise HIDs, Arqray SS Double Tip Exhaust, RAC Monolites
ekological is offline   Reply With Quote
