Old 03-22-2007, 06:58 AM   #30 (permalink)
macfly
macfly's Avatar
I'd suggest contacting Donelise on this board, he will be able to build you up a stoker motor, or you could buy a 3ZZ motor from Trial Racing in Japan.
There are two configurations, Standard and LTS
The 3ZZ LTS Engine includes TRIAL original forged pistons, custom made connecting rods, crank shaft, bearings and other necessary small parts.
With Japanese gas it puts out 230ps at 7700 rpm. Torque is 19.9kgm at 6840 rpm.
The price is ¥1,837,500.
That works out to be about $15,700.00
For both engines we use a combination of PowerFC (to control the vvc timing) and an HKS F-Con V Pro for the rest (both sold separately).
This engine is set up to stand up to forced induction.
The current compression is 13.5:1 and the rev limit is 8800rpm (if you plan to go turbo, you might want to lower compression)
The Standard engine uses fabricated stock parts so you get a little less power and you don’t want to boost it.
Price is ¥945,000 yen (about $8,000 US)
Power: 214ps @7700rpm
Torque: 19.9 @6840rpm
Compression: 12.5:1
Rev limit: 8300rpm
macfly
LA CA USA
BMW Z8
macfly is offline   Reply With Quote
