Old 03-26-2007, 11:01 AM   #17 (permalink)
waydui
GR8 SCAPE
waydui's Avatar
STAGE 2 INSTALL - UPDATE
I finally finished putting the whole thing together, including the black powder-coated diffuser panel and Sector 111 "boomerang" tow hook.
Powder-coating was $50.
I bought the Exige diffuser edging (silicone split tubing) to get the black color. The Elise tubing is silver. Silicone is a PITA to glue/bond to powder-coated metal. I ended up using Loctite "superglue".
I also used some garden sprinkler system hose, which I split with a razor blade and snapped onto the edge of the diffuser. Much easier to work with, but a little thicker, and heavier, too.
The tow hook was simple to install. I bought some additional hardware: spacers, lock washers and longer bolts to attach the piece.
To keep the tow hook "tongue" from bouncing off the diffuser, I bought a pack of industrial strength Velcro patches. I put them all around the contact area on the tongue. Turns out that powder-coated metal is a "Low Surface Energy" (LSE) substrate, so I got some LSE adhesive and built an insert spacer with LSE adhesive on each side and put it between the diffuser and the Velcro pieces. Everything stays put now.
I like the new look and the Stage II is really a great-sounding exhaust!
Regards,
Wayne
_______________________
