Old 04-11-2007, 10:21 AM   #36 (permalink)
waydui
GR8 SCAPE
waydui's Avatar
Originally Posted by def
Are you sure we need to blow this up... Wayne did you? Anyone?
I DID NOT blow up the document, I used as it is and did not have any issues cutting out the enlarged area to the right size.
The PDF itself is only a few millimeters (2-3mm per locus) off the diagram specs. There was more than enough clearance once I cut the diffuser.
Regards,
Wayne
_______________________
