Old 04-23-2007, 10:23 PM   #47 (permalink)
def
...ault
def's Avatar
I haven't had that happen or heard of it... Did you tighten the hangers down enough? I used the stock clamp, but I don't think I had much overlapping pipe from the cat. I centered the exhaust, and I don't think I could have gone any more to the right, or there would be a hole/leak. (does that make sense?) I was worried, but all is well here. I may go back in a few weeks and make sure everything is still tight.
The exhaust probably does rattle/move some during use, so if it's very close to the diffuser, I guess it could vibrate against it? You should post a pict of how close it is... or maybe take the diffuser off and see if something else is causing the rattle?
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more SOLD
def is offline   Reply With Quote
