What engine/tranny will be in the car?
The engine will be the Toyota engine and tranny used in the Celica GTS. It will be tuned by Lotus to put out 190hp and with a higher 8500 rpm redline. The 6 speed tranny will be the one use in the European Celica.
This engine should drive the car from 0-60 in 4.9 seconds (4.7 seconds with the Sport Package) and hit 140mph and do the 1/4 mile just over 13 seconds.
Here are the tech specs;
-Engine; toyota supplied, 4 cyl, DOHC 4 valves per cyl with variable valve and lift
-1.8L
-bore/stroke; 82.0mm /85mm
-max power; 190hp@7800 (DIN 70020)
-max torque; 138lb/ft(181 NM) @ 6800
-Compression; 11.5/1
-fuel cap; 10.5 us gallons
-clutch; 6 speed close ratio with single dry plate clutch
-Ratios; 1st/3.17:1-2nd/2.05:1-3rd/1.48:1-4th/1.17:1-5th/.92:1-6th/.81:1-final drive/4.53:1
Lexus GX-470 tow vehicle.
