Old 05-21-2007, 12:17 PM   #11 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Shouldn't we assume they WILL require replacing if you scape them?
I mean this isn't some miracle material that will slide over concrete without getting any marks, is it? The benefit is that these pieces will take the scraping instead of the clam. They are much easier and cheaper to replace once in a while instead of your clam. That's the whole point, right?
xtn
