Originally posted by zvezdah1
surfer, did you look in the blaup manual for setting your equalizer? I did, made all the diff. But the small cockpit and restrictiion to where the speakers can go is the problem.
But you can set up automatically using the little mic it has or you can do it manually, they have a chart as to how to set up manual depending on the sound. As you say, I didn't have nearly enough bass. much better now. Equalizer instruction begin on 31, with manual info and chart on 33-35.
Should help.
Chris
I thought you weren't going to bother with the automatic equalizer calibration  :
I did read the manual and you're right about the mic. Just not that big of an afficianado of car stereos that I'll probably ever use it. Don't want the stereo to get in the way of the glorious exhaust note.
"If you think conventionally and expect the ordinary, this is not for you."
—Lotus Engineering
