Originally Posted by Ian
I've actually been using Mr. C's mount as a camera mount. A few bolts and washer from home Depot and voila! I wanted to post some pics, but it's hard to take pics when my camera is mounted in the car. If you are only using the V1 or the camera, and never both at the same time, you may want to think about this.
Ian,
I'm glad the bracket worked out for you as a camera mount...
It should be possible to drill a hole in the bracket for the mounting screw if someone likes to. I kept the rib in the center of the mounting surface a little wider just for that reason.
Steve
