Good to know, thanks... It's hard sifting through the many many many threads on this topic...
I've pointed this out several times before, but here it is again.
The toe-link bolt is also the lower a-arm bushing mounting bolt. Only tighten that bolt (and any other bushing bolts) with the car at ride height - wheels on the ground. If the wheels are "drooping" with the car on jack stands, it will "pre-load" the bushing - besides causing the bushing to fail sooner, it will mess up the effective spring rate of the suspension.
Put the wheels on the ground or on RhinoRamps (or something else) so that the weight of the car is on the wheels prior to tightening the suspension bolts.
