Lotus cup holder
I just finished installing the Lotus cup holder and the screw to the right of the track which holds the unit to the underside of the dash won't tighten fully. There are 4-5 threads still exposed though the contraption seems to be securely held to the underside of the dash. Has anyone else had this problem?
Aside from that, the assembly doesn't seem as if it will hold a reasonable amount of weight. I guess it may not be designed to, as the inner diameter of the ring is pretty damned small. Perhaps I should have searched for another solution.
