Originally Posted by 4carl
what will fit in the rear with the harness bar. i had 6 1/4s in the elise but had to do some grinding looking for a direct polk drop in . are the rears 5&1/4s and the fronts 4s? thanks carl
Hey Carl,
The db650's fit in mine behind the harness bar, but without the grill. No drilling was needed, though a tiny bit of hole extension on the mounting screws might've made it a touch easier. There are some who have squeezed the grilles in, but I don't like the look of the grill so left it off. The rear oem is 5.25" but the polk 6.5 fortunately has nearly identical mounting hole spacing.
The Exige' I believe has a speaker pod that mounts the speaker a bit lower, so it should fit without a problem. I recall seeing a post where someone put them in without issue.
The db400's are drop-ins for a 4" replacement, and I'm using the oem grills on those.
Mark
'95 Miata M Edition. '05 Arctic Silver..Nitrons, Arqray Twin Muffler, SectorIII bar, carbon console and shift knob, Schroth harnesses, GUT spoiler, tie rod reinforcement, and lots more....Sold
