Thread: Accusump
Old 10-30-2004, 11:06 AM   #13 (permalink)
Stan
Possible accusump aid...our cars come with a bleeder near where the oil filter lives. See PIC below. If this is on the motor side of the thermostat, after the filtered oil ideally then this would be a nice spot to plumb into. There may be others, or the plate could be drilled and tapped to suit.
(You can also see that there is room for a larger diameter / length oil filter if that was desired....You can also plumb an accusump right into a Canton Mecca oil filter if you change the end plate)
