Old 09-27-2007, 08:30 AM   #17 (permalink)
Lotusmotion
Keep it simple and real
Lotusmotion's Avatar
Charles Rozier...+1, you and I have similar set-ups. My Exige runs at 130mm height (barely makes it into my driveway / scrapes at times), AO48s at the track, TP set at 8 in front and 7 in rear at the track, -1 degree camber in front, -2.25 in rear, 0 toe-in in front, and 2.75 toe-in at rear, and anti-roll bar at middle setting (3rd / center hole of the 5 hole settings).
The car feels relatively neutral and very well planted. I noticed the body roll when reviewing track day pictures of my car as well as other cars.
Inside wheel spin would not be an issue with stiffer springs as my Exige is equipped with LSD.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: X balanced - RTD brace - Manly inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - Green Filter - Larini - oil temp & pressure gauges - gPan - wheel studs & lugs - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disabler - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional.
Lotusmotion is offline   Reply With Quote
