One thing that was skipped in the instructions.
When you are cranking the engine, open the throttle fully. It does make a difference in the pressure readings that you will get, and it will come up to full pressure much quicker (with less drain on the battery).
Tim, I believe he covered that in step #12.
"12. Hold down gas and clutch at the same time, crank engine over about 6 times, until needle stops jumping on compression tester"
