Thread: Engine Oil
Old 11-01-2007, 06:51 PM   #49 (permalink)
jhnmdahl
jhnmdahl's Avatar
Originally Posted by vyuen View Post
I've wondered what the same engine in the celica requires as well and fundamentally it should be the same. That Lotus specifies a slightly heavier weight oil maybe due to the higher engine temps since our engine is mounted midship and there is less cooling.
I believe only the Exige S comes with dual oil coolers as standard spec (other than maybe the new supercharged elise).
The specified oil for a single engine can vary with intended use, with a change in redline rpm, or for other reasons. If you bought a GT3 version of the Exige with 270HP, Lotus might well recommend a 20W-50 instead of 5W-40 to minimize engine wear, and recommend oil changes every 500 miles. Put the same engine in a Corolla, and now fuel economy, desired service interval, and other factors may dictate a 5W-30 that gets changed every 7500 miles. That's one of the reasons it's hard to say any one weight is the optimal or perfect weight for an engine, or even a particular car. That said, Lotus seems particularly likely to make a sound recommendation based on the engine and type of car, and although I use an unusual oil I do buy a 5W-40 weight (at least during warranty).
John
jhnmdahl is offline   Reply With Quote
