Old 11-06-2007, 07:03 PM   #4 (permalink)
chuck_risen
Director of Engineering
chuck_risen's Avatar
Location: I live in Glen Ellyn IL, a suburb of Chicago.
Originally Posted by has6601 View Post
How much for the fiberglass enclosure with no sub? also, I currently have the JL Stealth box and it sounds pretty good and I was wondering if you have heard one before? if so are they pretty comparable? one last question, any rattles with the fiberglass enclosure?
The girl is complaining about leg room, so I may have to get something else soon.
Thanks
Sure can. I can knock off what I pay for it which is $100 from my supplier bringing the cost to $500 plus shipping. I can not guarantee that what you pick will fit but here is a drawing of what I use to see if what you have in mind will work. I couldn't find a drawing for the JL sub (I am assuming you want to use your current driver) so you will have to measure it yourself. This is a recessed design so the sub will have to fit in the same pocket the Clarion does.
Name:  Clarion PFW 1051.jpg
As for the JL I have not heard one in person. I can tell you that what I use is a 300W RMS sub verses their 150W RMS sub. They are both sealed design and look to have approximately the same internal volume. One thing I can say is that you can feel the music out of mine in your seat if you want. I did consider using their subwoofer in my design but twice the power and the cast aluminum frame of the Clarion won me over. My third choice was for a Rockford but it was not released when I designed the enclosure. I have always been a fan of Rockford and even turned down an engineering job from them back in the mid 90s which I have never forgiven myself for.
As for rattles I have not heard the box rattle at all. It is a tight fit in the rear back panel and is held in with 4 SS screws into the internal extruded aluminum frame.
Speaking of leg room the only drawback that I feel my system has is that you loose your last notch on the driver seat in terms of adjustment. I am only 6' so I don't need it but if any of you tall folks are thinking of one you will want to know this.
Chuck
chuck_risen is offline   Reply With Quote
