Old 11-10-2007, 05:43 PM   #6 (permalink)
MikeW
Originally Posted by mark.r View Post
To clarify, on '05 cars if runs in parallel with the stock ECU to run the dash. On '06/'07 cars it runs in parallel with the stock ECU running the dash and the throttle by wire. As Randy stated if you toss the dash you can toss stock ECU but then you have to be concerned with emissions. As far as the '06 (and later cars) there is some work being done to address the throttle by wire issue, meaning giving the EFI control of the throttle. I personally will never get ride of the stock ECU completely simply for the dash and emission reasons. As far as engine management the EFI controls everything.
Mark, if I remember correctly, you had some idle issues being worked out. Something due to the throttle by wire? How did things work out?
MikeW is offline   Reply With Quote
