11-13-2007, 08:14 PM
#5 (permalink)
Originally Posted by MotorCade
approx 2 hours... Jack car, remove wheel, remove castle nut cotter pin, remove castle nut, remove three hub bolts (the hard part, tough to get to and probably rusted - removing undertray for wrench clearance is probably necessary). Use a gear puller to remove hub, then replace new hub, connect ABS sensor, replace three hub bolts, replace castle nut, replace cotter pin, replace wheel.
did the bearing fail?year miles? carl
