Originally Posted by 4carl
i'm firmly convinced its a lubrication issue what I'm not convinced if its only a misaligned hole. one thing to consider is the cam is very close to the oil hole when the cover is on that makes any difference in the angle smaller. one thing that should be measured is the distance between the holes . do they match the center of the lobes? if in fact its a run of bad covers all cars that were repaired will fail again we need more data ..carl
These are all good points and We did measure the holes in relation to the center left to right and all were within a 16th of center of each cam lobe! The spray angle is reduced as you get closer to the source and crude measurements show a clearance of around 3/4 of an inch from the lobe to the oil hole when the cover is on and even at this distance the oil stream is missing it's mark (center) and not providing the designed lubrication. Definately agree more data is in order !
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
Knowledge is knowing a tomato is a fruit, wisdom is not putting it into a fruit salad.
