Originally Posted by Sh4rkattk
How about the side marker bulb near the door.
The side marker uses a clear bulb already. There is an orange lens built into the sidemarker that needs the be removed. I used a knife and needle nose pliers to remove the orange part, then installed the Stealth bulbs.
Basically, you can only use the stealth bulbs if you modify your sidemarker lenses.
