Old 02-04-2008, 03:27 PM   #44 (permalink)
goelise
AR #1275
goelise's Avatar
Images: 1
This is the approximate orientation of the screwdriver that you'll need to remove/pop loose the front turn signal light:
You can see the light gray tab in the pic below that you'll have to push on with the screwdriver:
If your having trouble, lay on the ground and look straight up with a flashlight shining up the access hole. You will see the light gray tab and it will help you find what your supposed to be pushing against. Actually, you can see the light assembly begin to move as you apply pressure to the tab.
Hope this helps someone.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace
Thank you FVMC! WOO-HOO!
goelise is offline   Reply With Quote
