Old 02-06-2008, 06:51 AM   #15 (permalink)
Dave
Mods are good for you
Dave's Avatar
Originally Posted by scottyb View Post
Very sharp looking. Dave can you show us a picture of your mounting solution inside the clam?
I'll try to get a pic this weekend...should have taken some along the way, but must have been too anxious Here were my steps:
1) I put the platform on the car; used a grease pencil to mark the 3x3 holes. Remove platform, drilled holes in clam.
2) Cut 2ea 4"x8" pieces of aluminum, and set the platform on them as a hole guide, drilled holes. Then mounted to the underside of the clam with epoxy. Make sure the aluminum is flexible enough to contour to the inside of the clam.
3) Applied 1/4" automotive foam adhesive weather seal to the perimeter of the upright bases. This filled in any small gaps between the clam & uprights, and keeps the water out.
4) You need screws that are about 15mm longer than the supplied, so I bought some M6x1x40mm stainless, along with 30mm washers.
The whole thing didn't take 2 hours.
Mod Maniac: '05 SY - Supercharged (3.2") TVS soon! . EFI Engine Management . ACT HD Clutch . FF Cold Air . Center Fed Fuel Rail . Catch Cans . PPE FI Headers w/ 2Bular 6" . Ported Throttle Body . Black LSS . Braille 9.5lb B129 . Boot Lid Pin . LED Tail Lights . CF Console . CF A/C Surround . CF Diffuser . FF Half Lip Spoiler . Custom Gut Wing . B&M Shifter . Painted Stripes . Rubbertite Mats/Buttons . S111 Booty. HIDs . LED Lighting . VonHep Dash Bag . Tinted Glass . Tesprit Mirror
Dave is offline   Reply With Quote
