Old 02-07-2008, 01:50 PM   #130 (permalink)
JonOrangeElise
JonOrangeElise's Avatar
Originally Posted by mrluky View Post
As of the last few months, I've been ever increasingly enamored with breaking rear traction in the Exige. Ive been experimenting with different inputs, and taking mental notes of events that, in practice, are way different than I what expected, in theory.
All of the following situations are on clean, wet roads, with wear bar rears, NA Exige. no LSD. TC off(and performed on a closed course). unless otherwise noted.
This is what I call a controlled slide, in that what happens, in practice, is what I expected to happen, in theory:
Approaching a turn, in gear, turn in, and apply throttle. The rear breaks loose. Counter steer. Spinning rears. Minuscule amount of lift(<1mm. Adding throttle, or maintaining throttle, I found, just spin the tires), and immediate(the lift and reapply is one motion of up-down asap) reapply of throttle brings everything back in order quickly.
I found that sometimes during mid slide, lifting(TINY amount of lift. 1mm max) stopped the increase of slide angle(spinning rears), and reapplication of throttle straightened it out smoothly. It depends on the amount of throttle used during initial breaking of traction. The lift helps tires grab. Now I'm not sure, since I didn't try, but I think if I didn't lift in the instances where I did, I would have spun right around.
Besides slight throttle input variations(noted in parenthesis above), this is a constant, controlled, repeatable event. This is what I usually try, and successfully, attempt.
Unexpected events:
1. Mid turn, rear breaks loose, total lift. Counter steer. Throttle. Car straightens out. No additional slide angle.
2.As noted in the "controlled" paragraph, following proper theory(apply more throttle) didn't work in some instances.
Before, I always thought that in a slide, one must not lift. But after these events, I can only come to a conclusion that a throttle induced slide requires different actions compared to a throttle-lift included slides. And lifting once over steer has occured doesn't
Anyway, I think that covers it.
Thoughts? Additions?
Disclaimer: Anything you do in your car is not my problem.
Thoughts/Additions: One would have to be an idiot to try car control exercises anywhere but on a skidpad, autocross, or (maybe, possibly) a track. Were you really doing this on a public road? You have to be kidding us, right? You have always seemed like such a wise, level-headed dude.
2005 Lotus Elise, "the orange car": hard top, touring, starshield,
orange/black Lotus Sport seats, 6-point Schroth belts, 4Tress Harness Bar,
SJ Racing 15x7/16x8 track wheels (plus stock wheels for the road), RTD Brace,
HIDs, Safety Solutions R3 Head & Neck Restraint System
2006 BMW M3 Competition Package, "the blue car": stock
JonOrangeElise is offline   Reply With Quote
