Old 02-10-2008, 09:46 PM   #162 (permalink)
turbophil
Plug Whisperer
turbophil's Avatar
Images: 6
Originally Posted by ChrisH View Post
Phil,
I know this was discussed a bit before, but just to be clear, is there no way of keeping the stock rear panel, even if supported differently, and even if the one has to remove the diffuser and remove some rear panel screws from the inside? (It doesn't take very long to remove the diffuser.) I like the stock rear panel.
Well, to say there's no way would be a stretch. You could leave the rear panel on and just remove it prior to tilting. It would take a little of the sex appeal out of the clamhinge, as you would then have to remove your diffuser and rear panel before you could tilt...So what's that take? 20 minutes? So with the rest of the kit installed minus panel eliminator... soup-to-nuts, you could tilt your clam in 25 minutes with some basic hand tools (tools needed to remove panel and diffuser only). If you opted to use the panel eliminator, you're tilting the clam with no tools and if under 5 minutes... Choice is up to you. Depends on how much you like your rear panel... Point is that you can work it however you like...
Best,
Phil
'05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 280whp/180wtq | EFI Standalone Engine Management | BOE Fuel Surge System | BOE Lotus Tow Package
Please Visit My Website: www.boefabrication.com
Creativity & Innovation by Lotus People For Lotus People
Somethin ain't worth do'n, if it ain't worth do'n right
