As of last week RCR has sold 16 rollers.
Superlite Coupe
Rolling Kit for $43,995
Needs engine and trans
Aluminum radiator
Twin electric fans
Stainless steel cooling tubes
Stainless steel and braided brake lines
Triple pedals in stainless steel with master cylinders and brake bias adjuster
Collapsible steering column
Quick release steering wheel
Cable shifter
Custom fiberglass seats
Digidash pro dash
20 circuit colour coded wiring harness
15 gallon fuel tank mid mounted behind seat per Le Mans spec
Functional roof scoop feed cabin with aircraft style vents
DOT windscreen
Hinged rear glass for engine access
Chassis mounted adjustable rear wing
Pushrod rear suspension
Engine bay will accept any longitudinal engine trans package
Production car style dash
AC system
Gelcoat finish body with Stainless steel alignment pins
4 inches ground clearance with removable side skirts and front spoiler for track package
Rear diffuser included
1400 LBS as a roller less engine and Trans, etc
All of the above is included the deluxe package
www.Six-River.com
Turbo cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world.
