Old 04-01-2008, 08:37 PM   #1 (permalink)
Doghouse
Doghouse's Avatar
New intercooler alternatives..
OK, so there been a lot of teasing going on around here about potential (some sub $2K, some not) solutions to the air flow / heat soak issue for the Exige S intercooler.
To recap the various threads on this issue and based on my notes we have (in no particular order):
Option a) SHOCO's reverse air flow system that ducts cool air from the sides and out the front of the intercooler. (removal of stock ducting from roof required). Cost about a few hundred dollars, but has anybody (besides SHOCO) installed and verified this works??
Option b) Ade, Ronin and others... A/W Proalloy intercooler system which requires clam removal and plumbing. If you go for the full Ronin you need to add an additional heat exchanger up front and convert your oil coolers and install a new oil cooler setup somewhere. IMHO, the Ronin solution is a bit overkill, but given his apparent inclination to go for the technically maxed out limit on everything.
Option c) Thomasio's mystery wrapped in an enigma solution with which he has been teasing us all with.
Again looking back through the various threads and knowing that Thomasio has access to CNC mandrel bent aluminum and knows how to use it, here is my best guess as to what he's up to, and I invite you, my dear reader, to speculate along with me...
I think it is ___insert your text here___.
No really take a stab at your best guess as to what you think Thomasio is doing. Let's see how close we can get.
From the Doghouse
2007 Exige S - Arctic Silver w/ Black racing stripes
If you believe that you are on the road to heaven, you may really be on the road to hell.
Doghouse is online now   Reply With Quote
