Old 04-02-2008, 05:34 AM   #12 (permalink)
Doghouse
Doghouse's Avatar
Originally Posted by Ade View Post
Just to get things in perspective the Proalloy system does not require you to use any other front heat exchangers than the one supplied, I suspect Frank now does not really need the others he is using, but they are already connected so why not.
The only thing I would make sure you do is buy the more expensive kit and install the new alloy engine rad as the thermal dynamics are so much better than the standard one.
Ade,
I 100% agree with your note. The additional heat exchanger and converting over the oil coolers to help is not needed. The Proalloy set-up (new radiator / new intercooler heat sink / new intercooler) should be more than sufficient. While the Ronin / Frank solution is technically pretty cool, IMHO it is overkill. I'd really like to see the temperature drop of water / coolant across the last heat sink. I bet the drop is not that signficant and thus the benefit not as great. There has to be a point of diminishing returns.
From the Doghouse
2007 Exige S - Arctic Silver w/ Black racing stripes
If you believe that you are on the road to heaven, you may really be on the road to hell.
Doghouse is online now   Reply With Quote
