Thread: In car video
Old 04-10-2008, 02:40 PM   #34 (permalink)
ZJChaser
Blue Wheel Pimp
ZJChaser's Avatar
Originally Posted by Eye Candy View Post
Most people don't think it is a good idea to suction cup a camera to the outside of the car, for safety reasons. Even though the camera is light, at 120 mph on a straightaway it could be a fatal projectile.
suctioned to the front with zipties as well in case the suction breaks.
Originally Posted by Toad View Post
Are you keeping it in its underwater casing? The mic is in the back,and inside the casing the sound is dreadful. However the casing is required to use with the mounting tools provided in the kit. To get optimum sound you have to put it in the low audio setting to remove wind noise and audio clipping. To get fairly decent sound you have to take it out of the case as was suggested by some spec miata/911 forums that I visited, and fabricate mounting the camera.
Good luck, and look forward to seeing your results on youtube.
I'll probably be looking at chase cam as my cheap camcorder hiccuped ,and now generates corrupted .avi files w no eof markers, so I can't sync up with traqmate data files. I already have a bullet cam w an external mic.
I dont plan on using the sound from this camera. Mainly just the video. Will use the sound from the incar cam.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
