Old 05-03-2008, 02:32 PM   #10 (permalink)
good2go
good2go's Avatar
Originally Posted by Beanie View Post
Thanks for doing the dyno. I'd already ordered a set and was planning on doing a street dyno (using software). Maybe the improvement you reported earlier was just due to replacing an old set of plugs with these new ones... or where the Iridiums you tested against your original plugs?
I dyno tested with the same original NGK Iridium plugs that I had prior to installing the Pulstar plugs - same showed in the photos. At time of testing, the original NGK plugs had about 1100 miles and Pulstar plugs had about 300 miles.
good2go is offline   Reply With Quote
