#21 (permalink) |
Form and Function
Yes, Willow eats your left tires...
Guys this is how bad my left rear was after the 3rd session: ![]() Right tire: ![]() And this is how it looked when I got home...: ![]() I know...lucky to get home....I will now have a set of street wheels and track wheels...Volks to come!
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 Last edited by plastique999 : 02-10-2009 at 09:16 AM. |
#22 (permalink) | |
User Restricted By ΑDMIΝ
![]() ![]() ![]() ![]() Corded? What cords????
#23 (permalink) |
I think they make a patch kit for that.
2007 Exige S: Solar Yellow. Lotus Challenge Series #101 2009 Nissan GT-R: (Sold) 2007 International 8600: 450HP/1500TQ Tow vehicle 2008 Benz S550 |
#24 (permalink) |
Form and Function
... kind of like it'll buff right out.
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#25 (permalink) |
JabStrongFierce
duct tape can fix anything
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#26 (permalink) |
Form and Function
#27 (permalink) |
JabStrongFierce
Which ones did you get??
#28 (permalink) |
Analyzing the parameters of "Omega" at Big Willow... two laps from two different sessions...
EDIT: Annotated graph with track info...
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 02-09-2009 at 11:32 PM. |
#29 (permalink) |
Form and Function
Well, i want to get the CE28's in bronze...but we'll see.
Andy, interesting data....what explains the dip in the red graph on the RPM's...is that a shift? Are the longitudinal g's considered acceleration and braking? What is the circular graph in the lower right hand corner showing?
#30 (permalink) | |
Yes, longitudinal g's are acceleration and braking. The circular graph is a "G circle"... it shows the path of G forces in two dimensions, so that you can more clearly see transitions from braking to turning to acceleration. The closer you stay to the outside of the circle, the closer you are to using the maximum grip of the tires. There's a mode where you can "play back" the data, and you can watch the path of G forces wander through the G circle. EDIT: See annotated graphic for more detail...
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 02-09-2009 at 11:29 PM. |
#31 (permalink) | |
SKYVUE
![]() I've got the car, now I just have to live up to the expectations! (I probably won't, but I'm having fun trying!) Carl's old Elise is enjoying a second life, taking it easy at a slower pace and giving it's second owners (Terry and I) a fantastic ride on the road of life...on the track or in the canyons! ![]() --Hal P.S. Andy, Eddie, Peter, Jack and others: you're living your own dreams! I hope you're enjoying it like I am. The pics here show that you are definitely having a BLAST! Be safe......
--SKYVUE Resident Astronomer '05 Saffron Elise,SOLD! '07 CaymanS Last edited by SKYVUE : 02-10-2009 at 06:32 AM. |
#32 (permalink) |
JabStrongFierce
awesome Andy - of the one time I have driven the track, the toughest part for me was knowing how much to lift on that double apex in turn 4. We're always taught to "never lift" but just from sitting with Craig he lifts there to hit the second apex...just a hard judgment call after charging up the hill under full load I was always worried the car would get too light during a minor lift to finish the turn.
#33 (permalink) | |
#34 (permalink) |
SKYVUE
Fantastic (and fascinating) data, Andy!
As to Craig's video in Franks modified Elise, it does show that he is fighting the steering all the way. Jack: thanks for the insight. Damn, now I'm fired up for a track day. When's the next? SOW, Big Willow or BW? --Hal
--SKYVUE Resident Astronomer '05 Saffron Elise,SOLD! '07 CaymanS |
#35 (permalink) | ||
Form and Function
#36 (permalink) | ||
I'm glad you're getting fired up! I'm not sure what my next track day will be, but stayed tuned and I'm sure you'll see what everyone else is up to... Quote:
#37 (permalink) | |
Form and Function
Can you explain the circular graph regarding the flatness of the top of the circle going from 0.4 to 0.2 along the x axis? ....
#38 (permalink) | |
Form and Function
His lines are pretty tight too.
#39 (permalink) | |
)... ideally that line should be symmetrically flat from side to side. Imagine powering out of the apex of a corner... you go from maximum lateral Gs to maximum acceleration Gs as you unwind the steering and go to max throttle. If your car cannot exceed the tires' grip from pure acceleration, you can basically use the rest of the grip for turning... so the graph would be flat from the center outward to the radius that equalled the tires' maximum grip.
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 02-10-2009 at 10:59 AM. |
#40 (permalink) |
Form and Function
o.k....now makes sense.
and how about the squiggly lines on the right where the 2 dots are compared to the smooth curve on the left - is that right and left hand turns/g's?
