#61 (permalink) | |
When I was driving a second or two slower, the brakes lasted a lot longer. I think I might have to upgrade the heat capacity of the system if either I or the car get any faster. But for n/a stock and 048's, I think it's pretty good. |
#62 (permalink) | |
Brake Guru
![]() Join Date: Mar 2008
Let me try to re-phrase what I'm trying to say. ZJChaser, you are having issues with "overheating". But what is actually overheating in your situation, and what are you experiencing when this is happening? I'm going to assume that at some point, your current brake system is overheating and you are not able to stop as fast as before the overheating begins. You could be overheating the following: 1. Brake Fluid (it will boil) 2. Brake Rotor (it will start deforming at a certain temp, and will melt at 2500* F) 3. Brake Pads (outside the temp range there will be reduced/no friction) So you are either boiling your fluid or your brake system is heating up to the point where your brake pad is no longer in its efficiency range. I can't find the temp range on the Porterfield R4, but here are some maximums: Pagid Black works up to 1200F. Pagid Grey works up to 800C (1472F). Hawk HT-10 works up to 1400F. Hawk DTC-70 works up to 1600F. Furthermore, if you look at this chart, you will see a difference in friction between the Pagid products. ![]() From our experience with WRX/STI (350+BHP / 3000-3300 pounds) the HT-10/DTC have the same or more friction then the Greys. In conclusion, the amount of heat generated will be the same, however you should choose a pad that will give you high friction at the elevated temperature levels.
http://lotusbrakes.com Your source for brakes! AIM: bigbrakeparts E-mail: sales at bigbrakeparts.net Phone: 781-347-4237 Snail Mail: 300 Andover Street #124, Peabody, MA 01960 |
#64 (permalink) | |
Brake Guru
How did these work for you?
#65 (permalink) |
this is where my experience/comment came from.
anything other than this set-up, i cannot comment with any experience, so i will not try to do so.
1977 Crossle 32F 1999 Spec Miata 1987 Porsche Spec 944-2008-2009 season SCCA AZ regional Champion 2008-2009 SCCA AZ Regional "Driver of the Year" |
#66 (permalink) |
More track time please.
Pads: Adare motorsports pads
Rotors: Ultra discs Fluid: the one that comes in gold or blue. I have the blue in now and will switch to gold for the next bleed (March) stock type fliud Tires: R888 stock sizes. |
#67 (permalink) |
Brake Guru
Now that the DBA 4000s are available, wanted to revive this thread just to see what has changed in 6 months.
-G
#68 (permalink) |
Pads: Cobalt Friction XR2 front XR3 rear
Rotors: Stock Fluid: ATE Tires: 048's My Pagid blues were worn and I asked Eddie at Adrenaline Racing to sell me a set of Pagid Blacks. He talked me into making a change to the Cobalts. He even drove out and met me at the track and put them in during the drivers meeting! They are really powerful. Saved me some money and wow, I'm no longer thinking about AP calipers.
05 Elise - Storm Titanium, Red interior. LSS, TP, HT, Starshield. Mods: Katana SC, Morosso Oil Pan, De-Snorkeled, Green Filter, billet oil cap, RTD brace, tinted windows, stainless brake lines, Cobalt Friction pads, FIAMM horns, Sector111 bootie. |
#69 (permalink) | |
Pads: Cobalt Friction XR2 Rotors: Blackwatch racing 2 piece Fluid: Motul RBF 600 Tires: Hoosier A6 or Toyo R1R The Cobalts were recommended to me by a race shop who had hooked me up with some parts in the past. I had been having what I thought to be "ice mode" moments with my old setup so I figured why not try something new, even if it wasn't the pads it couldn't hurt right? Wrong. I only did two track days with the Cobalts, one in the rain and one in the dry; unfortunately they left a layer of rusty brown brake dust on the wheels (two different sets ) that still won't come off. I've washed the wheels at least 5 times with every wheel cleaner and even oven cleaner I could find, scrubbed them with a plastic brush, even tried scraping the residue off with a plastic knife, and just tonight I began to hit them with a Dremel/polishing wheel and tar remover. The crud is finally starting to come off, but its going to take a few more hours at least, and perhaps a bottle of single malt scotch.I noticed after my first track day (it rained that day so I used Toyo R1Rs) with the Cobalts that the dust was on there pretty good and wouldn't come off with a simple spray and rinse like it used to. The dust also turned rust colored but I figured it would come off with a good scrubbing. Anyway, I had another track day coming right up and didn't have any other pads to swap them out with so I covered the other set of wheels I was going to use for my next event (it was dry so I ran Hoosier A6s) in Pam Cooking Spray, an old racers trick to make the wheels easy to clean... and even that didn't work. The dust from the friggin Cobalts ate through the Pam and still stuck to the wheels. The performance of the Cobalts was otherwise fine but due to the ultra toxic dust I wouldn't recommend them to anyone unless you throw your wheels away after each use. I picked up some Pagid Blacks so I'll report on them next time around. |
#70 (permalink) | |
Thoughts? Gary |
#71 (permalink) |
Plug Whisperer
That is correct. When brakes go to the floor, the fluid boiled. Get some real fluid. ATE is good and priced right. Have 2 colors, amber and blue, so that you can tell when your fluid has fully flushed through the system. Change every other track day or so if you use your brakes hard and boiling should subside a good bit. Venting helps a lot too. Rotors will help a little.. and every little bit helps. The fluid will help a lot as will frequent changes.
Good luck, Phil
'05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 280whp/180wtq | EFI Standalone Engine Management | BOE Fuel Surge System | BOE Lotus Tow PackagePlease Visit My Website: www.boefabrication.com Creativity & Innovation by Lotus People For Lotus People Somethin ain't worth do'n, if it ain't worth do'n right
#72 (permalink) | |
Brake Guru
Basically you are probably getting the system hot enough to get the DS2500 out of the heat range and they are transferring that heat straight to the fluid. I would recommend stepping it up to some race pads (we recommend the Hawk HT-10s) and maybe some DBA 4000 rotors depending on your current rotor conditions. Check out our Hawk / DBA page ** HAWK / DBA End of Year Super Christmas Sale ** with links to the review threads and special Christmas prices. -G
#73 (permalink) | |
So Ate is considered better than Motul 600? I thought it was the other way around (I don't have the comparative specs in front of me). Someone suggested going with a high boiling point synthetic fluid. Thanks for the input, Phil. Gary |
#74 (permalink) | |
Gary |
#75 (permalink) |
Blue Wheel Pimp
Motul needs to be flushed within a 6 month period. Keep it fresh and you'll be fine. Also thin pads will heat the fluid faster.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
#77 (permalink) |
Plug Whisperer
Gary,
sorry, didn't see that you were already running good fluid. In that case the ate obviously won't help. So I agree just renew the fluid and keep it fresh. Moisture is a problem and the temp swings make it worse. Renew the fluid frequently. Ate is nice because it's different colors and cost half of the 600 with similar performance. Cheaper means you don't feel as bad about changing it often. Add some of Brents ducts as well if you're still having problems. Of course driving style will make a difference as well... Phil
#79 (permalink) |
Blue Wheel Pimp
I just stick with Motul, as long as its fresh, no problems...
On a side note to track brake setups. I had a few boxes from Performance friction show up. I'll be testing a few different compounds of theirs. I can already say that the quality of the pads are nicer than any others I've seen, now to see how they perform.
#80 (permalink) | |
I didn't see it addressed. But the brake balance changes when the coefficient changes... So a higher coefficient will have more braking in the rear and less heat in the fronts. Of course you do not want to be locking up the rears (in a non ABS version anyhow I know you don't want that) |
