Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
Old 10-23-2008, 02:15 PM   #1 (permalink)
Elise Royalty
Patricko's Avatar
How can I make my exhaust quieter?
I don't want to change the exhaust.
Can I bolt something on the tailpipe?
Do these work? How many DBs should it take off? Any downside?
SuperTrapp: Performance Exhaust
I have heard of people putting rubber hoses on the tailpipe and pointing them at the ground. Does that work?
I might like to run Laguna Seca but I am way too loud now.
Patricko is offline   Reply With Quote
Old 10-23-2008, 02:20 PM   #2 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
you cant be louder than the p2 cars there just last night
silly noise rules
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 10-23-2008, 02:31 PM   #3 (permalink)
LarryB's Avatar
Was at Laguana several years ago with Chococar. Think he was ~5dbA over. He came ready with some tip extension to direct the exhaust away from the sound station. That didn't help. He also had a Supertrapp but needed some welding to get them mounted. That didn't happen and he ended up lifting. Not sure if he'd been back since and ran with them.
I'd be a little careful and you may want to do more digging about simply slapping a Supertrapp on. It will also increase back pressure, which a FI car may not be too happy with.
LarryB is offline   Reply With Quote
Old 10-23-2008, 02:35 PM   #4 (permalink)
Patrick, you were suppose to call me once you took final ownership of your 211. Call me now and I'll tell you what tricks can be done for Seca to make your pass sound levels.
Corvus is offline   Reply With Quote
Old 10-23-2008, 02:50 PM   #5 (permalink)
Elise Royalty
Patricko's Avatar
Ring Ring...
Old 10-23-2008, 03:05 PM   #6 (permalink)
DPM
DPM's Avatar
It will definitely be LOUD with a Supertrapp. We are pushing at least 105 DB with the Diasio. Sounds really good though! Just have to wear a good set of earplugs.
2006 Diasio D962R Arancio Borealis
SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet"
DPM is offline   Reply With Quote
Old 10-23-2008, 11:40 PM   #7 (permalink)
My other car's a mtn bike
R'elise Me's Avatar
Patrick,
Try the Larini 8". Very quiet, nice on the brain. I'm fairly certain it will pass LS standards. I have one if you want to borrow it for the event.
Glen
Sometimes you have to go in circles to move forward.
05 Elise NA 1750 lbs w/ full cage, fuel cell, aero, 173 whp - Colin would be proud.
2008 LR3 HSE
2005 Mini S Convertible
If I'd thought that one day ALL my cars would be British, I'd have laughed at myself!
R'elise Me is offline   Reply With Quote
Old 10-24-2008, 12:02 AM   #8 (permalink)
without a Lotus
FLuXeXigeS's Avatar
add an inline resonator
as you know they come in different sizes and shapes, heres an example
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 10-24-2008, 01:04 AM   #9 (permalink)
zuoom's Avatar
get a control valve. (basically a butterfly valve added inline)
it will quiet down the xos alot. but do remember not to go high revs when the valve is on the semi closed position.
| CelicaSG.org - CSG |
zuoom is offline   Reply With Quote
Old 10-24-2008, 02:03 AM   #10 (permalink)
Lancia's Avatar
I've heard of good results with an inverted cone, usually after the muffler.
They can be mounted so they can be removed.
It's not supposed to affect back pressure.
I'm not familiar with the exhaust you have.
Have you thought about the multi-tube Borla?
I have seen them in carbon fibre, though probably experimental only.
I use a turndown and that is supposed to make a difference, though I've never tested it.
Often reducing harshness is more important to the perception of noise than the db level.
Lancia is offline   Reply With Quote
Old 10-24-2008, 03:36 AM   #11 (permalink)
#334
Chococar's Avatar
I haven't been back yet, but I will have the Supertrap on the diverter when I do. I think I got a few dB reduction from the diverter by pointing the exhaust away from the meter, but it wasn't enough to be helpful. Short-shifting or lifting both worked, but I would up short-shifting because it was more predictable. I was right at the edge all day.
I love Laguna Seca -- I can't believe I haven't driven there recently
Good luck!
--Joe
Old 10-24-2008, 06:50 AM   #12 (permalink)
Patrick, get a stock S muffler and cut the exit pipe where it comes out of the muffler that's what the factory did on Jacks car. Good seeing last weekend. carl
User formerly known as 4carl
carl is offline   Reply With Quote
Old 10-24-2008, 08:18 AM   #13 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
at one race I saw a lot of Porsche guys with the rubber elbow clamped to their pipe. I assume it works.
SweetDaddyD is offline   Reply With Quote
Old 10-24-2008, 08:22 AM   #14 (permalink)
Elise Royalty
Patricko's Avatar
That comes out of the bottom, I need the side for the 2-Eleven.
Old 10-24-2008, 08:29 AM   #15 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
electronic exhaust control valve:
A'PEXi U.S.A. - Products: Exhaust
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 10-24-2008, 05:39 PM   #16 (permalink)
Mimzy's Avatar
I have a Super Trapp muffler on my Mazda Rx-7(first gen, headers to straight through exhaust). It is plenty loud but this nice thing about this setup is that it is easy to make it quieter. They usually come with twelve discs and the more that you install the louder it gets. Someone spoke of creating to much back pressure with these but, you can actually create negative back pressure with enough discs. Also you are able to tune the engine somewhat by adding and removing discs. More discs are supposed to make it run leaner and fewer make it run rich. For a good street sound that is not too obnoxious 6-8 discs are pretty good. I run twelve and it annoys people.
Mimzy is offline   Reply With Quote
