Ice mode does more harm than good, with video example
Someone dumped their radiator full of fluid in the hardest braking zone of my favorite track, and I was the first person to "discover" this situation. I pushed my brakes only to find a rock-hard pedal and hardly any braking force, I figured huh, that's odd, I don't usually get ice mode here, but I did the standard thing, let go of the brakes, and try again, but to no avail, a wheel or two must have still been sliding, so I stayed in ice mode and couldn't bleed off much speed. I had to take a sharp turn way faster than possible to make it, and aim the car into a grassy field away from tire walls. Fun.
Other cars which hit the slick spot got wiggly and some got sideways, but at least their brakes worked. Lame.
Damn that sucks but hey it could have been alooot worse. Have not had the ice mode experience yet. Still apprehensive about it. I flush all brakes and clutch before every event. I do brake at hard at 3 cone though and carry speed through corner
On cold wet days, i can get ice mode on a straight line while driving under normal street speed conditions.
The system is simply set up wrongly by Lotus.
This isn't 'ice mode' - it's simply ABS. Coolant is crazy slick and coated the tires. The idea behind ABS is to allow the tires to keep rotating or else steering inputs are useless. You see, you were able to still steer because ABS was doing its job. There's just not going to be any stopping power at all with glycol on your tires
That was my 1st thought. I think our ABS cycling interval is very long (2 sec ?) and always assumed it was a product of the GM/Opel sourced system.
When I've encountered either pure ABS or "ice mode", I have to let off the brakes for a full one-one-thousand count before it resets.
In the video, it looks about 1 sec from braking zone to your fully committed to the off.
Hey, at least it's better than 1st gen ABS of the early 90's. I remember experiencing virtually useless 2 channel systems, where you could really feel the ABS pump @ ~10 hz.
Glad you had grass!
OK re-reading about ice-mode, it's possible I've *never* experienced pure ABS, so all my pucker moments have been this... yeah not fun.
No, I'm sure it was ice mode. I hit ABS all the time on track, even on full slicks. It has a very specific pedal feel. ABS in this car is very high frequency and you can feel a buzzing, but the pedal feel is fairly normal. Ice mode makes the pedal feel rock hard, and it doesn't depress as far - it's like there's something between the pedal and the floor.
I know roughly how much grip I had based on how hard I was able to turn, and it was way more than my brakes were letting me use. There's another turn on that track where the rear inside tire gets real light, and I can hit ice mode 100% of the time, and actually have to be careful there every lap.
It's a bad system unless you're driving on ice I've driven many cars at the track, and let me tell you, the Elise is the only car that I've encountered so far with this strange braking behavior. I like ABS enough that I'm not willing to sacrifice it by pulling the fuse, so I just deal with the ice mode.
Yeah, T10 can do it, especially when cresting the small hill just before the turn-in zone. I get it almost all the time braking up into T5 over the crow's nest, if I've got any steering input while braking, so I have to make sure to brake there absolutely straight, then turn in. Normally, I trail brake into turns as much as possible.
Hah! Yep, T5 as well. That's my 2nd most likely ice mode corner. If nothing else it's useful (or reassuring?) to know the problem is consistent/repeatable. I trailbrake both 5 and 10, but ice mode in 10 kicks in during straight line braking... Way before turn in. At any rate, now I just anticipate/manage the issue. I too would rather not give up ABS, which I find pretty unobtrusive and helpful in this car.
I was having all sorts of braking problems on a bumpy track, I have none now after the following:
Disable ABS with fuse
CL RC6 pads all around
Stainless lines all around (when I only had in the rear I think this was causing trouble).
Pull vacuum lines all apart and make sure they are plugged in right front and rear of car and check valves work.
Now the brakes work awesome all the time and they are pretty modular so I don't typically have trouble with brakes locking up.
It's easy to avoid T10 ice mode at Thunderhill. The problem is that there's a little hill just before you see the T10 turn-in point, and when you're cresting that hill with full brakes, the car gets light and some wheels start to slip under braking, and ice-mode kicks in. Brake a tiny bit earlier, and as hard as you can on the upside of that little hill, then ease off a little as you crest, and back to full brakes. I've been doing that forever and I haven't experienced ice mode there since. As for T5, meh, it's a throw-away turn, so a little sub-optimal entrance is no big deal.
If I'm not mistaken, the ice mode tell tale is that the pedal gets unusually stiff. I've not experienced the hard pedal yet myself, but definitely have used the ABS functionality. I'm prepared to pump the brakes in that moment, we'll see if I remember!
One note about the Sector111 write up vs what I read from drivers... Sector111 indicates that you can still just press on the brake hard and it should stop, whereas I read many drivers describe the brakes nearly quit working.
Of course, on track when you are trying to drive the car at or near 100%, ANY braking reduction is a potential problem. Coming in at near max speed though a pool of antifreeze just before a tight turn is going to put you in a pickle, ice mode or not.
Hi marcinr, I 'm sorry to hear you had this happen, scary place for it! I'm glad all is okay. I too have had ice mode into turn 10 at Thunderhill, but fortunately without any coolant to make the ride more "entertaining" haha. Even that was scary so I can only imagine...
The interesting thing here is that my experience was in an '05 Elise but I have since switched to an '07 Exige S and I do not have that problem any more. I have only hit ice mode once, very briefly, in the 'S and that was under hard braking on some sandy gravel someone had pulled onto the inside of a corner at Buttonwillow. I wonder if the design, or even the factory settings (?) are different on some cars because my Elise would go into ICE mode pretty regularly (especially at autocrosses, during the first couple of runs when the course wasn't clean yet).
For those of you that haven't had it, it is very different than the ABS feel, as described, like a very hard, ineffective pedal with a different pulsing feel than the ABS, very unsettling (especially since it usually happens when you need it most, and it usually catches you by surprise unless you are doing the same thing again like at a track or an autocross).
The other interesting thing is that when it did happen in my 'S, it went from ABS pulsing, into ICE mode, then back to normal ABS mode pretty smoothly so I had a lot less of that panicked screaming sound in the car, haha. Makes me wonder if there is a way to transfer some sort of programming from a car that works well to one that doesn't? I am not a tech guy so that may not be possible.
Any thoughts on this out there? It would be great to be able to cure this problem on those overly sensitive cars without having to disable the ABS...
And now that I have read the Sector 111 link I have to agree with the comment that the article there does not describe what it actually feels like or how the car seems to behave. There is DEFINITELY way less braking ability in the front of the car, and it does not come back in the front with more pressure. I am 6'-3'' 200 pounds and with full force on the pedal almost no front braking remains even after the gravel/sand/whatever has been passed over (if you keep your foot on the brakes). And the pulsing is slower than ABS mode. It does not behave like it is just the rears being locked out of the circuit, more like all four brakes are locked at a much lower level of braking ability than in ABS mode.
Pumping quickly does remove it, but it is very hard for your brain to go there (or at least mine) with the sudden change in your braking ability when you need it most and are not expecting it.
I'm not so sure if this is a natural consequence of the requirements which you mention, because, other cars' brake controllers seem to handle this far more gracefully. I wasn't the only one to hit this slick, for instance, and I've also engaged ABS on quite a few different cars on the track, only the Elise seems to have this bizarre behavior.
The track guys, and particularly the auto-crossers know well about whatever "ice mode" is, and it's a design problem in the braking system for those particular uses. I don't know if you've ever hit the ice mode in your car, but it's positively frightening, even if you hit it on the street, because braking force is severely limited. My guess is they've done this to prevent creating a yaw moment on the car if one side is on ice, but it seems to engage way too aggressively and stays engaged until releasing the brakes.
I have hit it a few times, especially when I had heat-cycled and cold R888s and I have also professionally calibrated ABS systems for several race teams, so I have an extremely good understanding of how the theories work.
The Lotus manual even states that the ABS is intentionally programmed to allow more slip than most, but this is why then it has to try extra hard to make sure this slip is not exceeded since there is less margin for error. I am not saying the calibration could not be better, but it is at a reasonable level for production calibrations that have to be pushed through fairly quickly. Especially since I would recalibrate a car if it had a pad change and nothing else. The tighter your tolerances are, the more important it is to model the entire system accurately. One car, for example, ran best with a specific combination of master cylinder and brake pads and changing the pads from that made it very hard to get the ABS just right for the driver.
With all that being said, I did some reading in the service manual and found some interesting stuff. My first thought about why the pedal stays dead until you repump it is because there is no way to increase the pressure other than hitting the pedal anew. Actually though, the Lotus unit does incorporate an electric pump that raises the pressure when in ABS. It is possible that this motor is underperforming or underspec'd and cannot provide enough pressure fast enough when the full system has been bled but it works fine for moderate interventions. I don't know the specifics of this system well enough to speculate further than that though.
Interesting stuff, cyow5. Very cool that you program ABS systems for race cars. I had no idea how sensitive they were (brake pads even) and I like your broom analogy, haha.
Are ABS systems usually controlled from the ECU? Sorry if that is a dumb question but I am new to this. Because if so I wonder if you could switch ecu's (or?) from a wrecked car that you knew didn't do the ICE mode "thing" (like my Exige vs my former Elise) and solve the issue without much fuss.
Just a thought.
Whatever controls the programming it sees like there must be different settings from the factory on our cars otherwise more people would experience it more often (I may be wrong but it seems like not that many people have had it happen). That could explain the difference between cars going into ICE mode, or not, under very similar circumstances (stock brakes, LSS wheels, R888's on both cars in my case).
Whatever controls the programming it sees like there must be different settings from the factory on our cars otherwise more people would experience it more often (I may be wrong but it seems like not that many people have had it happen). .
Have been watching ice mode threads (and complaints) for about 10 years. This is a prevalent problem. I actually would hazard that people DO experience it quite often. But it's a track phenomenon, and my own anecdotal observation is that it increases as people really begin hitting the brakes hard, and have modded the car with some aftermarket combination of wheels, tires and/or brakes. If it doesn't seem commonplace, it's perhaps because there's no fix other than behavior modification (avoiding triggers; mitigating effects), and folks have just given up trying to resolve a mechanical fix that preserves ABS.
Car-chitect, the ABS logic is in the ABS module itself, it sits in the front left wheel arch.
Much as ice mode annoys me, the ABS system in the Elise is quite good. When engaged in regular mode, it does a fantastic job braking, almost as good as perfectly executed threshold braking. You know crappy ABS when you hit it - the car, pedal and steering wheel start shaking.
In my case, I'm running carbotech XP12 pads, which have a much higher friction coefficient than stock, and I'm running soft compound racing slicks, which have a far higher coefficient of friction than stock tires. The net result is that the normal rate of wheel deceleration is far higher than something you would see on the street, and yet, the ABS system handles it just fine the majority of the time. I moved my brake bias a little bit forward by using less grippy rear pads, and the incidence of ice mode became less common.
Like cyow5, I've also written control system code using limited sensor input, and it's a challenging problem! ABS is one thing, but today, stability control is mandatory, and getting that stuff working is both really cool and a bit of black magic - accelerometers, gyroscopes, high rate wheel speed sensors, combined with a model of what the car should be doing versus what all the sensors are telling it. Fun stuff
marcinr, very cool, I'm always impressed with how much knowledge there is on this site!
So is the ABS module like a mini computer that only handles brake/wheel sensor input? Is it something that could be easily switched from one car to another? Or are they really just all exactly the same from car to car so it wouldn't make sense to even bother, and maybe I just haven't had the identical situations in my 'S as in my Elise?
Not being a coder I am lost as to how this all works, but I definitely get that there is a lot of black magic that goes into it. These dynamic stability control systems where the inner front wheel is progressively braked to help turn-in when understeer is detected, etc. -very cool and interesting stuff. Magnetic ride height systems, progressive lowering of ride height at speed, etc. I can only imagine the arrays of sensors needed to communicate and safely react to any possible situation, with lots of testing involved, but still on a budget. Except in formula 1, haha. Though there, even though all of this has been outlawed, even more complicated code must be needed for managing the ERS, KERS, braking, diff controls (corner entry, mid corner, corner exit), hundreds of sensors, etc. Wow!
And agreed about the Lotus ABS, it is really good if you don't hit ICE mode. I have super crappy ABS in my pickup, always locking rears and making the front useless. I think it must be set for a fully loaded truck (makes sense because with more weight you'd need it more) but still no fun when you don't want it and the truck is empty.
So the Lotus is great deep into a corner, even on stock brakes and R888's
I've experienced the ice mode a few times on the street: usually it happens when a stop light changes abruptly and I try to brake too hard over rough pavement. The lss wheels and springs with dunlop direzza tires just seem to bounce over the pavement. In these situations, my other car has no problem (not even engaging the abs), but the lotus does not inspire confidence. That hard pedal and feeling of lost brake performance makes me feel like it's safer to just not even try to stop.
Funny enough, I haven't seen ice mode since I left Michigan Granted, that's about the time I changed tires, but I still like blaming that state for everything, haha
So I am wondering if there has been any kind of survey about whether the '07 and later cars experience ICE mode less than the '05's, indicating the programming may have been changed in the ABS control module and therefore if you switched modules to a later one you could reduce ICE mode. A brief search, and reading through some other ICE mode threads, found nothing yet.
From acslater's description, that is what I did in my '07 Exige S (it felt much more normal, smoother, not panicky) and I notice he has an Exige in his avatar, but what he describes as "pushing through" did not/could not happen in my '05 Elise and it looks like marcinr, cyow5, and Obeisance all have '05 Elises.
Any thoughts? It might be a hard survey to do since there are so many more '05's than later cars...
They changed suppliers for the ABS at least once, but I don't have the specifics right in front of me. There very well may have been calibration changes along the way, too. I believe the switch from Kelsey-Hayes to Bosch was pretty late though towards the end of the federal run, so I'm not sure if those even made it here. Reading other threads on here, it seems the Kelsey-Hayes system is pretty crude and lacks some of the extra sensors like accelerometers that really help improve control. Funny enough, one thread suggested buying a Bosch M4 ABS kit which is what I used to calibrate. Now that would be a sweet retrofit, haha. This thread also mentions a variety of years all having the problem, so it could be a natural consequence of not having the best system.
I would say that they are largely in agreement, in my experience. But then again, I'm running the 315/330mm AP Racing BBK, so it's possible that the additional advantage of the size of the brakes makes "pushing through" much for effective than for the stock setup. I dunno :shrug:
Related Threads
The Lotus Cars Community
2.7M posts
51.4K members
Since 2002
