Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
Old 10-01-2009, 03:05 PM   #1 (permalink)
2007 Exige S
robains's Avatar
Laguna Seca runners past and present, sound?
I usually don't like to do Laguna Seca because of the sound restrictions being so low (92db day), but an Oct 26th event offer is hard to pass up.
I'm not concerned about my exhaust, it's VERY quiet. But, I'm concerned about the noise of my MP62 @ 10 psi with FF tube and K&N -- it's noisey.
For anyone that has run Laguna with MP62 and open intake, were you able to pass sound with the intake opened up?
Thanks Rob.
Old 10-01-2009, 03:26 PM   #2 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
larini 8" + Weapon r header will not pass sound generally. I added a ubend and a von hep to the end of mine and barely passed.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 10-01-2009, 03:33 PM   #3 (permalink)
2007 Exige S
robains's Avatar
No worries on exhaust, I'll be putting my stock header and BOE/Phil's quieter muffler on -- I'll bring the cat just in case.
Primary concern is the supercharge whine from my MP62 @ 10 psi.
Rob
Old 10-01-2009, 03:39 PM   #4 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
oh ok you should be fine on the exhaust. I have a cup air box with the opening cut a good bit larger and am making ~11psi and passed ok. I think my exhaust was the bigger issue. I do think your intake sounds a bit louder than mine though.
Old 10-01-2009, 03:46 PM   #5 (permalink)
2007 Exige S
robains's Avatar
Hmmm...ok, thanks -- I might work on some type of intake noise reduction or just bring my stock airbox (just in case) -- I can always tune for optimal power at the track with my EFI and datalogging
(shameless EFI plug)
Rob
