Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
Old 06-03-2009, 09:22 AM   #261 (permalink)
Form and Function
plastique999's Avatar
Originally Posted by Tom_Hughes View Post
Brent reported that in the race he experienced ice mode (hard brake pedal and not much stopping) into turn 3 and a bit of a close call with Rob.
How many others experienced ice mode this past weekend at BW?
How many others have tried running with ABS disabled?
Opinions of running with ABS and without ABS?
As most of you know I run with ABS disabled, but my brakes aren't exactly stock: Lotus Sport brakes on the front same as Cup car, LPL brake calibers in the rear to move brake bias towards the rear, larger vacuum reservoir, Cobalt pads (custom compounds through HyperSport). I've never had ice mode with ABS disabled, but as I showed in the race - can't have any inaccuracies in corner weights or one corner will lock-up and unstable braking or even a spin.
Sounded like Kevin's braking problem in turn 2 that led to car to car contact was not ice mode, but not completely clear. In my car, with ABS enabled, I can induce ice mode in turn 2 very easily.
Why don't you guys just disable ABS?
Ice mode sounds dangerous - I'd rather lock up brakes than hit Ice mode
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 06-03-2009, 09:25 AM   #262 (permalink)
Form and Function
Originally Posted by kaz View Post
Convert it to a .wmv or xvid first, should be much smaller
and again...those times you were pulling and everyone else...just crazy
Frickin Mac won't take Chasecam vids directly....ok so I will upload to PC then how do I convert it on a PC (I am PC illeterate)
www.FaceNBody.com
Old 06-03-2009, 09:35 AM   #263 (permalink)
i use "MPEG Streamclip" on the Mac. You can download an MPEG2 codec for $20 from Apple but it only permits playback -- not very useful since VLC can playback just fine without any add-on.
road racer is offline   Reply With Quote
Old 06-03-2009, 09:42 AM   #264 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
+1
I've done both... if I'm going to edit a video I usually convert it to .mov with Streamclip, and then use iMovie.
Old 06-03-2009, 09:51 AM   #265 (permalink)
Form and Function
Originally Posted by apk919 View Post
+1
ok, I've dl'd the MPEG streamclip and moved the chasecam vid into it, but I see nothing....but the time is ticking - is it converting??
www.FaceNBody.com
Old 06-03-2009, 10:06 AM   #266 (permalink)
+1
for iMovie HD (iMovie 6) you want to convert to DV format. that is iMovie's native format and converting to anything else just results in a second conversion when importing into iMovie.
for the new iMovie, it works on the native format of the movie and creates an EDL so that conversion only happens when you finally export/share the final production. however it doesn't understand MPEG2 so you're still stuck with double conversion, so again DV is the format to use.
hopefully a future version (or maybe with firmware upgrade) of chasecam will support MP4 recording.
or, of course, you could use a PC but i just find that to be an exercise in frustration.
Old 06-03-2009, 10:11 AM   #267 (permalink)
apk919's Avatar
Images: 20
Yes, you should see a progress bar somewhere, and when it's done, you should have a usable video.
Ahh, thanks for the tip!
Old 06-03-2009, 10:20 AM   #268 (permalink)
Form and Function
Thanks Andy, ok, it'll take 30 min. to convert, then I assume I will be able to upload to Vimeo.com ...
www.FaceNBody.com
Old 06-03-2009, 10:29 AM   #269 (permalink)
apk919's Avatar
Images: 20
Wow, that's one large video! But yeah, I suppose it can take that long... (I have an 8 processor Intel Mac, so it parallel processes the videos )
Old 06-03-2009, 10:56 AM   #270 (permalink)
rdsphotos's Avatar
MelroseMAC
Whenever you guys have issues let me know, that's what we do at our store
About Us | MelroseMAC
We are now offering any LCS member a cost+5% pricing on anything we sell ... just send me an email
rdsphotos is offline   Reply With Quote
Old 06-03-2009, 11:25 AM   #271 (permalink)
rdsphotos's Avatar
Eddie - call me and I'll get your vid sorted....Richard 323 937 4600 xt 245
Old 06-03-2009, 01:29 PM   #272 (permalink)
Form and Function
thanks Richard....will call you shortly
www.FaceNBody.com
Old 06-03-2009, 01:33 PM   #273 (permalink)
Master of Disaster
SteveLevin's Avatar
(nerd hijack) I'm stunned the Mac doesn't natively do MPEG-2. I've been looking at Macs and just assumed that they would handle it since it has been around for ages.
Steve
SteveLevin is offline   Reply With Quote
Old 06-03-2009, 04:58 PM   #274 (permalink)
Form and Function
Thanks Richard for the help, .... however, after 2 hrs of Fetch, it said that rdsphotos dropped the connection
trying again....
www.FaceNBody.com
Old 06-03-2009, 05:43 PM   #275 (permalink)
TWRD & Blip advertising
knucklehead's Avatar
Eddie if you don't get it sorted bring the CF card to Fontana this Saturday and I'll bring my computer and will convert it for you.
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is offline   Reply With Quote
Old 06-03-2009, 05:45 PM   #276 (permalink)
Steve
I think it's unfortunate that Apple decided to not buy an Mpeg-2 license, but it's worth the $20 to be able to work on a Mac.
Jacob
Old 06-03-2009, 05:50 PM   #277 (permalink)
apk919's Avatar
Images: 20
+1 on both points
Old 06-03-2009, 08:11 PM   #278 (permalink)
Form and Function
ok bought the stupid program and now converting....
www.FaceNBody.com
Old 06-03-2009, 09:09 PM   #279 (permalink)
Tom_Hughes's Avatar
LCS4 video from Tom's rear facing video, part1
Tom_Hughes is offline   Reply With Quote
Old 06-03-2009, 11:01 PM   #280 (permalink)
right seat driver
Brent Bauman's Avatar
Thanks Tom. Lap 1 at the Riverside kink looked as hairy as it felt
Nice shot of Glens 1st loop at cottons.
Definetly 4 off at sunset lap 2
can't wait for part 2.
Brent Bauman is offline   Reply With Quote
