Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
Old 08-27-2009, 11:41 AM   #1 (permalink)
New person with some track questions
Hello everyone -
I am brand new here. I will hopefully be the proud owner of an Exige in the next couple of months and I had some questions.
My car will be 95% track and 5% street. I wanted some opinions here on what should be modified first to make the car a better track weapon.
My first rounds of mods will be budgeted at around 5000.00 (not including the car and a trailer).
I have track experience with my current car (Audi RS4) But I just want something way more focused.
So with the 5k budget where should I begin.
Thanks,
Matt
Mattkaenel is offline   Reply With Quote
Old 08-27-2009, 11:47 AM   #2 (permalink)
06 S280
LordZ's Avatar
Which Exige and what options?
Toe link Brace - Sector111 RTD (unless you have the factory brace already)
Harness Bar - Sector111 (needed for harnesses below)
Harnesses - I went with just the 4 point (more of a comfort and safety upgrade)
Oil pan - Moroso (prevent oil starvation should you start pulling some decent g's)
Tires - I like the R888's or RA1's (biggest difference so far for me on track)
Brakes - carbotech (better bite than the pagids or stock)
Shocks/Springs - I just upgraded mine to Nitrons so still getting used to them.
LordZ is online now   Reply With Quote
Old 08-27-2009, 12:00 PM   #3 (permalink)
I am looking at an 07 Exige S with track pack.
Thanks
Old 08-27-2009, 12:01 PM   #4 (permalink)
Chili Red's Avatar
Thanks
LordZ hit the nail on the head..
2007 Exige S - Chili Red
2009 Mini Cooper S - Chili Red
Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera.
Chili Red is offline   Reply With Quote
Old 08-27-2009, 12:03 PM   #5 (permalink)
registered nipple
fishguy's Avatar
Images: 1
this should be first;
5-6 point harness, H+N restraint, proper racing seat
all the rest comes secondary
2008-2009 SCCA AZ Regional "Driver of the Year"
1986 Swift DB-1 Sold
2008 HSR-West FF 3rd generation Champion
2008 "The Series" FF 3rd generation Champion
1987 Porsche Spec 944
2008-2009 season SCCA AZ regional Champion
fishguy is online now   Reply With Quote
Old 08-27-2009, 12:05 PM   #6 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
no need to even touch the suspension off the start.
Moroso Oil pan
Track Pads, I prefer Hawk HT10
Toe link brace
Motul 600 flush
and as Fish said, safety gear, that up to you though and I'm not getting into that debate
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 08-27-2009, 12:20 PM   #7 (permalink)
06 S280
LordZ's Avatar
Yup, not starting the safety debate again...
If you have the track pack, that should include a toelink brace. Suspension is probably good enough until you get used to the car. I'd eat up the A048's then switch to something cheaper and a bit better.
If the car is used make sure to flush the brakes at least once a year depending on how much track time you do. 6 months might be better.
Oh, probably be prepared to buy a front splitter pretty soon too.
Old 08-27-2009, 12:21 PM   #8 (permalink)
Any recommendations on seats?
Also, installation of 5-6 harness in the San Diego area?
What about breaks?
Old 08-27-2009, 12:21 PM   #9 (permalink)
Jack's Avatar
Thanks
With the track pack, your car will already have the harness bar and
toe brace (the RTD, suggested above, is better when it comes to heim joint replacement costs), but there is no need to run out and replace your track pack rear toe brace.
Your car will also come standard with 10 way, single adjustable Bilstein coil over setup -- you probably should run the car that way for awhile to get used to its handling characteristics, which will be quite different from your awd Audi. Of course, plan on getting a track oriented alignment, including proper height settings and perhaps corner balancing before hitting the track. There is no doubt that you will want to upgrade the suspension down the road. You'll find that the car will be quite track worthy (from a handling perspective) with the stock track pack suspension once your alignment is set up properly. There are also some other "mechanical" items that you might want to consider to help preserve engine/tranny longevity, such as the already mentioned baffled oil pan, "catch" cans, stiffer engine mounts, MT90 for the tranny and the like.
Of course, get all the proper safety equipment -- we leave that discussion to fishguy, out resident safety advisor.
Enjoy the new car --- it's a great track car right out of the box.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 08-27-2009, 12:23 PM   #10 (permalink)
All good info. Thanks
Old 08-27-2009, 12:29 PM   #11 (permalink)
Jack's Avatar
What about breaks?
Brakes, per se, should prove sufficient initially .... as already suggested, you will eventually want to go to some race pads .... Pagid, Hawk or whatever brand you like.
You can decide later whether you want a "big brake kit" or some upgraded 2-piece floating rotors.
Just remember, the Lotus is a momentum car -- most of us coming out of much heavier, high HP cars always tended to over use the brakes when we first started tracking the Lotus. You'll see what I mean when you get it on track.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 08-29-2009, 05:51 AM   #12 (permalink)
Form and Function
plastique999's Avatar
if I had to do it all over again, I would have started with everything suspension related and tires.
Remove shims
Shave arms
Corner balance and alignment
Not sure if your car has adjustable sway bar
R888s
The hawk HT 10s have great bite
DEFINITELY moroso oil pan
Of course HANs and 5 point harness...
If you can get a used Reverier XC seat it fits like a glove....otherwise Bridezilla or maybe Tillets.
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 08-29-2009, 08:38 AM   #13 (permalink)
Left Lane Assasin
JungleJim's Avatar
Images: 12
It was only mentioned once but you should DEFINETLY upgrade the motor mounts. The stock units are very soft and allow a lot of engine movement. This causes among other things: dinged intercooler, sloppy shifting, cracked exhaust components leading to possible fire safety hazzard.
Agee with all said.
Keep the driver safe
Have Fun
Keep the engine safe
Have more Fun
Upgrade the suspension/brakes and any other mods to be cool in the motorpool.
Have the most fun
In that order.
2007 Exige-All Black and Mean, Factory TouringPak/TrackPak/StarShield/LSD/TractionControl/iPodDock. All stock but not for long.
v = square root ((2 * e) / m)
JungleJim is offline   Reply With Quote
Old 08-29-2009, 09:31 AM   #14 (permalink)
with future lotus driver
Conan's Avatar
Images: 24
lets assume you get the proper safety equipment first so I'll just wave my hands around that topic.
Personally, I think you should just get used to the car as-is, parts-wise. Have it corner balanced and aligned correctly and then drive it a while (on track and off) before doing anything to the car. Even if you are an accomplished driver, that will give you a baseline as to what YOU think needs to be improved . If you are new(ish) or haven't developed your skills enough, you'll just be wasting your money on parts you can't utilize.
Sum up: Get used to it as-is for a baseline and/or to work your way up to the car's OEM capabilities.
fwiw.
Yes, it IS my real name. No, I don't look like him. I'm Polish. Polish barbarians are skinny nerds.
2006 BRG Lotus Elise (broken), 2009 Honda Fit (gas miser), 2007 Honda Odyssey (the wife's)
Conan is offline   Reply With Quote
Old 08-29-2009, 09:44 AM   #15 (permalink)
spf4000's Avatar
Modified fuel tank should be on the list as well if you're gonna be tracking it that much to prevent fuel starvation.
spf4000 is offline   Reply With Quote
Old 08-29-2009, 10:59 AM   #16 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Another Exige S in San Diego? Cool!
Have you driven a mid engined car before? I have an Audi S4, and believe me, it's an understeering land yacht compared to the Lotus.
As others have said... get your safety gear squared away first.
Stick with the stock suspension and brakes for a while... but get it balanced, aligned and set up properly.
I'd upgrade to the Moroso pan before doing any other aftermarket upgrades.
Old 08-29-2009, 12:57 PM   #17 (permalink)
06 S280
LordZ's Avatar
fwiw.
I agree to a point, as long as he's aware that the "OEM capabilities" include oil starvation and weak toe links...
Apart from safety gear for the driver (obviously), safety gear for the car should be before anything else. Rear toe brace and moroso pan. I'd do those even before tires or new pads. You can always adjust your driving for pads with less bit as well as tires with less grip. It's much more difficult to adjust your driving for oil starvation or having a bolt come out.
Just don't go under half a tank and you will be fine. I have yet to be to a track that I couldn't make it half a day on half a tank without loosing track time to get fuel.
Personally I think the cost of the tank and labor is a bit high for not being lazy.
Old 08-29-2009, 02:34 PM   #18 (permalink)
registered nipple
fishguy's Avatar
Images: 1
this is good advice, and the route i discovered quickly as well.
I put on the moroso pan after the 1st track day, and purchased the rear toe brace also.
as far as the seats go, i have not seen them in person, but the tillets look like the nicest thing going so far.
I also found that the stock brakes were just fine( for me).
keep asking the questions, you are heading in the right direction.
josh
Old 08-29-2009, 04:18 PM   #19 (permalink)
06 S280
LordZ's Avatar
I didn't have issues with stock brakes or pads, I just liked the initial bite from the carbotechs more. My stock pads and brakes never faded, they just didn't bite in as hard as a few of the other Lotus' that I rode in.
I did switch off the stock A048s to some "rain street" tires with the RE01R's. Awesome in the wet, as we all know the A048s just plain suck in the rain. But on track the RE01Rs killed me in confidence and speed. R888's made the biggest difference to me on track than anything else I've done.
Old 08-30-2009, 05:22 PM   #20 (permalink)
Shawn C's Avatar
Harness kit,
Upgrade Pads/ Motul or Super Blue flush
Toe Link Brace, Moroso Oil Pan
Learn to drive the car well then...
Remove front Shims/ Swap Front sway bar for BWR, Coilovers, Have car corner balanced.
then it goes on and on.. These are the first and best mods to do IMO
Then add more power, But dont go puttin one of them dumbass spoilers on it.
http://www.youtube.com/jerusdc
Shawn C is offline   Reply With Quote
