Race-Technology DL1 datalogger & ECU interface question
What readings can I get from the ECU ?
and What other information would you recommend logging (via sensors) with the DL1 that aren't provided by the ECU?
2009 Starlight Black Elise R, Sports Pack, 240 Cup Rims, Yokohama A048 LTS, Φhlins Suspension Kit, AP-Racing Brake Kit, Chassis Brace Kit, Harness Bar with SCHROTH Harnesses, Lotus Motorsport Carbon Race Seats, AC delete, Stage 1 Exhaust, ECU re-flash |
#2 (permalink) | |
P0011 A Camshaft Position - Timing Over-Advanced or System Performance P0012 A Camshaft Position - Timing Over-Retarded P0076 Intake Valve Control Solenoid Circuit Low P0077 Intake Valve Control Solenoid Circuit High P0101 Mass or Volume Air Flow Circuit Range/Performance P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0111 Intake Air Temperature Sensor 1 Circuit Range/Performance P0112 Intake Air Temperature Sensor 1 Circuit Low P0113 Intake Air Temperature Sensor 1 Circuit High P0116 Engine Coolant Temperature Circuit Range/Performance P0117 Engine Coolant Temperature Circuit Low P0118 Engine Coolant Temperature Circuit High P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low P0123 Throttle/Pedal Position Sensor/Switch A Circuit High P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) P0131 O2 Sensor Circuit Low Voltage (Pre Catalyst) P0132 O2 Sensor Circuit High Voltage (Pre Catalyst) P0133 O2 Sensor Circuit Slow Response (Pre Catalyst) P0134 O2 Sensor Circuit No Activity Detected (Pre Catalyst) P0135 O2 Sensor Heater Circuit (Pre Catalyst) P0137 O2 Sensor Circuit Low Voltage (Post Catalyst) P0138 O2 Sensor Circuit High Voltage (Post Catalyst) P0139 O2 Sensor Circuit Slow Response (Post Catalyst) P0140 O2 Sensor Circuit No Activity Detected (Post Catalyst) P0141 O2 Sensor Heater Circuit (Post Catalyst) P0171 System Too Lean P0172 System Too Rich P0201 Injector Circuit/Open Cylinder 1 P0202 Injector Circuit/Open Cylinder 2 P0203 Injector Circuit/Open Cylinder 3 P0204 Injector Circuit/Open Cylinder 4 P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0324 Knock Control System Error P0327 Knock Sensor 1 Circuit Low P0328 Knock Sensor 1 Circuit High P0335 Crankshaft Position Sensor A Circuit Range/Performance P0340 Camshaft Position Sensor A Circuit P0351 Ignition Coil A Primary/Secondary Circuit P0352 Ignition Coil B Primary/Secondary Circuit P0353 Ignition Coil C Primary/Secondary Circuit P0354 Ignition Coil D Primary/Secondary Circuit P0420 Catalyst System Efficiency Below Threshold P0441 Evaporative Emission System Incorrect Purge Flow P0442 Evaporative Emission System Leak Detected (small leak) P0444 Evaporative Emission System Purge Control Valve Circuit Open P0445 Evaporative Emission System Purge Control Valve Circuit Shorted P0446 Evaporative Emission System Vent Control Circuit P0447 Evaporative Emission System Vent Control Circuit Open P0448 Evaporative Emission System Vent Control Circuit Shorted P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance P0452 Evaporative Emission System Pressure Sensor/Switch Low P0453 Evaporative Emission System Pressure Sensor/Switch High P0455 Evaporative Emission System Leak Detected (large leak) P0456 Evaporative Emission System Leak Detected (very small leak) P0461 Fuel Level Sensor A Circuit Range/Performance P0462 Fuel Level Sensor A Circuit Low P0463 Fuel Level Sensor A Circuit High P0480 Fan 1 Control Circuit P0481 Fan 2 Control Circuit P0500 Vehicle Speed Sensor A P0506 Idle Air Control System RPM Lower Than Expected P0507 Idle Air Control System RPM Higher Than Expected P0508 Idle Air Control System Circuit Low P0509 Idle Air Control System Circuit High P0562 System Voltage Low P0563 System Voltage High P0601 Watchdog P0606 Checksum P0627 Fuel Pump Control Circuit /Open P0638 Throttle Actuator Control Range/Performance P0646 A/C Clutch Relay Control Circuit Low P0647 A/C Clutch Relay Control Circuit High P1301 Misfire level causing emissions increase P1302 Misfire level causing catalyst system damage P2104 Throttle Actuator Control System - Forced Idle P2602 Coolant Pump Control Circuit Low P2603 Coolant Pump Control Circuit High P2646 A Rocker Arm Actuator System Performance or Stuck Off P2647 A Rocker Arm Actuator System Stuck On P2648 A Rocker Arm Actuator Control Circuit Low P2649 A Rocker Arm Actuator Control Circuit High |
