Track day oil or fuel starvation: How much to worry?
I track my Elise a couple days a year, and all this talk about oil and fuel starvation kinda makes me nervous. Are these types of failures common or rare?
Is there any relationship between fluid levels and likelihood of starvation? In other words, would driving with a full tank and/or over-filling the oil sump a little for track days help my odds?
Driving lights and a Lidbone. Oh, and a supercharger. |
#2 (permalink) | |
User Restricted By ΑDMIΝ
For oil issues, your oil level should be at max at all times. Not above and not below (within reason, of course). Again, strength and duration of G forces affect oil starvation, which can be remedied with a baffled oil pan, an Accusump, or both.
2007 Exige S
I was gonna say the problem is not as significant for normally aspirated Elise/Exige, but then I saw your "oh, and a supercharger".
It's a pretty significant problem, many people have lost engines because of it. I run Hoosier R6 compound and lost one motor because of it at Thunderhill CA long left hander. Got lucky on motor #2 (same track, same tires) as it encountered the same issue only with about 3 psi less pressure and a more safe tune -- but that motor dropped a valve about 2 weeks later just driving around the street. Motor #3 is surviving with BOE's fuel slosh solution. With Engine #1 and #2, the tank was filled up prior to each session on 100 octane race fuel -- didn't prevent fuel starve. My car is an 07, and by my first engine failure I only had about 5000 miles on it, Engine #2 lasted about 3000 miles. I "think" Engine #3 will be fine, but this Lotus has tossed failure after failure at me so who knows. I think normally aspirated Elise/Exige with stock rubber seem to encounter the fuel starve and oil starve issues much less. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
OSX Black hat
depending on the track / driving style people report fuel starve on a stock car at 3/4 a tank or less, stay about that and you'll likely never see it.
as for the oil, if you manage to starve it badly enough to cause damage then there is probably not a lot you could have done about it, so just check the levels each track day, if you notice the consumption going up then have it checked. The accusump/moroso help, addtionally adding extra oil capacity. like i said in the other thread, common sense, if something acts odd, sounds different etc, check it (though not by flooring it around a track or sitting in the pits free revving the engine to 6000 rpm)
If you don't make any changes to prevent it (Fuel or oil) then at the very least make sure that you top off the tank with fuel before every session and make sure the oil is topped off.
Yes, both are very real problems. I have the data that shows it.
Ralph Provitz 2008 WHRRI SM Champion 2008 WHRRI Top 10 Driver 2006 Exige V2 Motorsports |
I heard rumors of a dry sump solution....from v2 and monkeywrench
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
#8 (permalink) |
OSX Black hat
dry sump would be cool, lotus offer one too i think.
#9 (permalink) | |
JabStrongFierce
Anyways on top of what Charlie is saying an easy thing to do (which I am finally doing this week) is getting an oil pressure and temp gauge with some dummy or warning lights when the levels get funky...that and I'm just going to have to check oil levels over and over before each outing. No oil in my catch cans, but a steady loss of about 1/3 quart every 500 miles or so of hard driving or on track is what I am noticing.
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#10 (permalink) |
Form and Function
oh don't get me started on this....
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#11 (permalink) | |
registered nipple
I check my oil level in all my cars before each session, just like I check my lug nuts for torque before each session. tire pressures also. its part of a day at the track.
2008-2009 SCCA AZ Regional "Driver of the Year" 1986 Swift DB-1 Sold 2008 HSR-West FF 3rd generation Champion 2008 "The Series" FF 3rd generation Champion 1987 Porsche Spec 944 2008-2009 season SCCA AZ regional Champion |
#13 (permalink) |
I'll also throw in checking brake pads and tire wear.
#14 (permalink) |
2007 Exige S
So far the Moroso oil pan alone has done it's job in terms of oil pressure at various tracks -- I data log the pressure and lowest psi reading was 33 for a <1 sec rapid left to right (or right to left) transition that caused the drop. Steady state corners (like turn 2 at Thunderhill CA, or turn 6 at Infineon CA) will show around 50-60 psi. Rule of thumb is about 7 psi per 1000 rpm - or so I'm told.
Accusump can't do anything in regards to rapid transitions (<1 sec) that cause oil pressure drops (i.e around 1.6-1.7 G), accusump is for aiding longer steady state pressure drops. Dry sump would be interesting but -- can anyone expand on what type of dry sump Lotus provided? i.e. is it a true dry sump setup with a separate external oil tank or is it a hybrid system utilizing the existing oil pan? Electric or belt? Rob
#15 (permalink) |
JabStrongFierce
Of course lol...I'm talking about checking it like multiple times in a row, again my dipstick is somewhat uncooperative sometimes showing different oil levels in consecutive checks. I just checked it this morning again, first time normal, second time one side was covered other was empty with spotty oil to the first dot, 3rd time normal -
#16 (permalink) |
Engineer of Record
I am also nervous about this, I am doing my 1st track days in Sept.
but what I am hearing is if your car is NA, and you are on street tires, and you check fluid levels very diligently, things will be ok. yes?
02 Phoenix Yellow M3 (fast and fun) 06 Autumn Gold Elise (faster and funner) 07 328iT (wifey's car) |
#17 (permalink) |
2007 Exige S
No guarantees, but many seem to be ok -- how you drive and type of track will also play into the "safety" of your engine. If you wanna be more safe, I'd recommend you not exceed 7800 rpm.
#18 (permalink) | |
surfing leucadia
So, for those who've experienced engine failures, I'm just curious: Are you buying new engines out of your own pocket or is your Lotus warranty (don't laugh too hard, this is a legit question from this newby) covering you in some way? ![]()
07 AW Exige S - Track Pack, sun visors and rear view mirror removed 02 Subaru WRX Wagon - bone stock, 115K miles, running strong as ever 00 Toyota Tundra V8 4x4 - lifted, 33's, a bit beat up but gets the job done quite well |
#19 (permalink) |
2007 Exige S
My own pocket and then some. I do all the work myself, so I save about 6K in labor.
Warranty is pretty clear, take your Lotus to the track and warranty is void (this is not unusual).
#20 (permalink) |
British by extrapolation
Let's be realistic...first track days at 7/10ths pace with instructor in the car, fuel starve and oil starve should not be what these guys should be concerning themselves with.
Now, if you've tracked a lot and this is the first time you are taking the Lotus out, that's a different story...and your own experience should tell you if you need to worry about things like fuel and oil starve on high G, long sweepers...because you've probably had to concern yourself with it in other cars. |
