#21 (permalink) | |
McLareghini Bugatterrari
![]() I do know that you'd have to be driving a lot harder than I am to cord tires down from a point starting at the wear bars in just one weekend. My RA1s went six track days since running out of tread completely (slight evidence of the two main grooves remaining), and I finally pulled them off in disgust at being unable to get down to the cords. I suspect they still have another full inch of good rubber underneath the original tread. ![]() xtn
#22 (permalink) |
No, it's only an N/A
The OP didn't say what kind of tires he was using.
If he was using AO48s and/or AD07s then I would strongly suggest getting new tires instead of taking the risk of cording his tires while at the track. If this is his first HPDE then chances are that he won't be cording the tires, BUT it is pretty easy to cord them between driving to the event, doing the event and then driving home... especially if the OP has a bit of extra tire pressure at the start of his HPDE day (or weekend?). Also considering that the OP is asking this question in the first place I was assuming that he was NOT using RA1s. If he is using RA1s then he should keep the tires on the car and enjoy the hell out of them as they are just about to get great!
Useful links to vendors removed at Nadeem's request. "Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem" |
#23 (permalink) |
Exactly right Sir.
#26 (permalink) | |
2006 Elise Sport #46 ![]() |
