TonyM
06 Elise Choke around 3200+ RPM
I have a 06 Lotus Elise, recently the car has been choking around 3200-4000 RPM. It only happen when the engine is warm around 187degree+, morning and night are usually okay. Once it start to chock, the RPM needle will drop and it's hard to bring it back up, but once it pass 4000, the car drives okay.
has anyone ever have this type of experience before? Not sure what the problem is. Brought to the Dealer, the tech say it's the electronic throttle body needs to be replace ($2500). I just want to see if anyone else has the similar issue and fixed. Thank you
91, 93, 94 Toyota MR2 Turbo 01 Toyota MR-S 04 Scion Xa 06 Lotus Elise |
#2 (permalink) | |
2006 Phantom Black Exige 2004 Porsche C4S 2007 Black Hummer H2 SUT |
NOT ßANNED!
AC Relay (If AC was on at times of issue).. Change your air-filter, clean your MAF. Make sure throttle body isn't sticking.
GA2NYC2VA2NYC2NOVA2PHL
Check for recalls. I had my throttle body replaced on my 2006 Elise due to a similar experience. It fixed it right up. Any codes thrown? I would think it would be covered due to the recall. It's bulletin 2006/10 from 4/21/2006.
2006 Lotus Elise Sport, Laser Blue (Current) 1997 Acura Type R #85 Stock, Champ. White (Stolen/Stripped) 1984 Honda CRX 1.5 Blue (Sold) |
#5 (permalink) | |
TonyM
Thank you
TonyM
yeah, when I turn on the AC, the problem happen sooner. I clean the air-filter, but how to clean the MAF? and how do I know if the throttle body is sticking?
#8 (permalink) | |
TonyM
#9 (permalink) |
NOT ßANNED!
Did you try cleaning your MAF?
#11 (permalink) |
Engine stumble WOT
Check post #18 for an explanation of the MAF cleaning procedure. There's a tsb (technical service bulletin) about the AC relay causing problems in early dbw (drive by wire) cars. I believe a re-flash fixed the problem. I have an '05, so I have the old-fashioned throttle cable system ![]() Tom |
#13 (permalink) |
NOT ßANNED!
Disconnect it as mentioned in referring post above, spray it with MAF/Brake cleaner.
#14 (permalink) |
I have had some sillyness due to dirty MAF. I clean mine with every oil change (I use MAF cleaner). BTW, you will need a tiny, short phillips screwdriver....... don't drop the screw.
The first time it happened to me the engine would cut out at about 4K rpm. Until I figured out what was happening, it seemed like the car would only act-up during a entire drive cycle. After turning the car off it may or may not do it after the next restart. Good Luck
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles) 2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars) 2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator) Couple nice bicycles, way too many snow skis. |
#16 (permalink) | |
Come on down
'06 Elise Phantom Black, Touring, Starshield, Powder Coated Black Wheels, Bobble head IMUS |
#17 (permalink) | |
TonyM
I won't mind pay a couple of hundred for the problem, but Lotus service center want to charge me $2300 for the fix, I walked away. Notice one thing recently, the choking issue only happen when the temperature of the car goes up to 190+. Usually happen when I stuck in LA traffic for too long or when the car isn't moving from light to light during hot summer days, or Using AC and the temp goes up faster. Or else the car runs fine. Do you guys think it's the throttle still? because if the temp is low, the throttle react fine. Does that mean sensor or anything else?
#18 (permalink) | |
TonyM
Hi JoshS, where or which service center did you go? I would like to visit there if it's not too far, thank you ![]()
