Old 10-06-2009, 01:30 PM   #1 (permalink)
2007 Elise engine's harshness is killing me
Okay, the car's pretty much had this problem, well, forever. I'm finally found it too annoying to put up with. Drama queen time: The engine sounds like ****. Utter ****. It runs fine and the car has 13k miles on it. No power problems or anything like that - just sounds awful.
The problem: It sounds awful to me and the one friend I drive around with. The dealer couldn't hear anything. It's been serviced twice by separate dealers and I guess they didn't really hear it because it's subtle. I have no idea if all Elises sound like this. I doubt it. If so, Hethel needs a box of hearing aids.
Less overly-dramatic description: On top of "normal engine sound," there is a superfluous subtle but extreme harshness. If you just got in the car and drove it around the parking lot, you may not hear it. You'll most likely notice it when driving and letting off the throttle under engine braking, but it's always there. The point is: people are all about not having a stereo because the engine is the stereo - certainly not in this car. I want the stereo to cover up the engine sound.
I'm getting a GoPro camera to mount next to the engine to record the sound (instead of what I hear in the cabin) before I go to upcoming service, but anybody have any idea what I'm talking about? Is this normal?
The weight: If this is normal, which I doubt, that's it for the car.
NOTE: This is not the regular Elise problems that I also have: rattly windows, thunky dashboard, Brake light on left turns, etc.
Any clues?
2007 Ardent Red Elise with Sport Kit.
dead_ed is offline   Reply With Quote
Old 10-06-2009, 01:32 PM   #2 (permalink)
really light stuff
Thomasio's Avatar
Can you be a little more descriptive? Does it seem like valve train noise? Intake or exhaust noise? Gear / transmission noise? Metal vibration?
07 SY Exige S
Old 10-06-2009, 01:34 PM   #3 (permalink)
I'd look for exhaust leaks maybe..
also there could be a heat shield or something rattling once the rpms get high enough to cause enough engine vibration for some things to touch
could be lots of things.. just a few ideas to think about
gpheck is offline   Reply With Quote
Old 10-06-2009, 01:47 PM   #4 (permalink)
NOT ßANNED!
Demonized's Avatar
Take one for a test drive at the dealer, or have them drive you around for a few miles in one.
If the noise is also in a different Elise, get out of here! buy yourself an Escalade!
If not, good luck finding the problem!
Old 10-06-2009, 02:20 PM   #5 (permalink)
Thomasio, it's not my expertise, but it sounds like it's an aspect of the engine noise - it's right behind my head and seems related to what the engine's doing (it's much more obvious to hear when I let off the gas and just coast). This is why I'm just trying to get a recording of it.
Doesn't sound like an exhaust issue, nor gpheck does it sound like a rattle of something loose or something making contact. I can't guess what it really is, but it's NOT tapping or a valve-sound, but it could be more like a [air?] leak kind of sound. The car itself works fine, it'll haul like Jack the Bear - just sounds crappy doing it.
Old 10-06-2009, 02:22 PM   #6 (permalink)
Oh, I'm in Silicon Valley if anybody's wanting to compare.
Old 10-06-2009, 02:49 PM   #7 (permalink)
Seb
<3 QR25DE
Seb's Avatar
It could be your intake. That's right by your head.
Seb is offline   Reply With Quote
Old 10-06-2009, 02:50 PM   #8 (permalink)
NOT ßANNED!
Demonized's Avatar
If it's a whine, and mostly evident if coasting, while in gear, I'd vote gearbox noise.
Old 10-06-2009, 04:55 PM   #9 (permalink)
Clovis's Avatar
Images: 14
If it's a metallic whiring harshness you are hearing during constant throttle....I will vote throwout bearing. My prior Elise did this starting at about 7k miles and got worse up until 14k when I swapped the clutch and throwout bearing. Yep, sound went away. My Exige is now getting the same noise at 10k miles. Agree it is a nasty noise that you just can't get used to. Hoping to swap in a new clutch/pp/fw and bearing over the winter.
Clovis is offline   Reply With Quote
Old 10-06-2009, 04:59 PM   #10 (permalink)
http://homepage.mac.com/seaton/.Public/LTS_dead_ed.mp3
I made an initial audio recording (put on your headphones), but it's not revealing much. This was done in neutral in the parking lot. When I stuck my head under the car as far as I could get, I did hear something suspicious from front [car center] of the exhaust system so maybe the sounds just aren't coming from where I think they're coming. I'll pay more attention as I drive it home from work tonight and see if I can put a microphone in a more appropriate place (I just propped my iPhone in the bay for this one.) More research…
Old 10-06-2009, 05:03 PM   #11 (permalink)
Clovis's Avatar
Images: 14
BTW, to test for the bearing: Put the car in neutral and let the clutch out, rev to ~3,000 RPM and listen for noise. Press the clutch in and see if the noise goes away. If it does, it's the bearing as far as I can tell.
Old 10-06-2009, 05:03 PM   #12 (permalink)
yagobob's Avatar
this sounds like gearbox noise or the infamous "metallic rattle" that i've been hearing for for 5 years. it sounds like gearbox noise to me. i'm in the bay area too, i wouldn't mind having a listen.
yagobob is offline   Reply With Quote
Old 10-06-2009, 06:01 PM   #13 (permalink)
NOT ßANNED!
Demonized's Avatar
the... uhm... "thhthhthhthhthhthhthhthhthhthhthhthhthhthhthh " (sorta like a rolling "R" sound, but higher pitched) that's going on through-out the entire video while the car is running sounds like the valvetrain.
Every Elise I've ever heard run has that to some extent.
The high pitched "Virrrrr" early on sounds almost like the intake.
Old 10-06-2009, 06:31 PM   #14 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
That sounded completely normal to me...
Old 10-06-2009, 07:08 PM   #15 (permalink)
Thanks Clovis and everybody else - I'll try some more stuff on my way home from work. (Bonus points to anybody that found the transcript of the audio in the MP3's ID4 tags.)
Old 10-06-2009, 08:36 PM   #16 (permalink)
MikeinAlexandria's Avatar
Images: 5
I bought my Elise with 14500 miles on it. Driving it home, I noticed some pretty rough, mechanical sounding noises behind my head. I changed the oil twice over about a month, (to flush the oil cooler) and also changed the tranny oil. The noises aren't gone, but definitely greatly reduced. My engine runs smoothly at idle once it warms up a bit. The transmission still buzzes at little, but it is, right behind me.
I'd suggestion changing your oil and transmission fluid, using great, synthetic products. Then see how the sounds are. It's gettting close to winter, so not a bad time to do this. I am actually thinking about one more oil change before the weather gets really cold, along with brake fluid and a coolant flush (It's been about two years since these have been done)
Good luck. Record a video and post it so we can hear your car. I might do the same to compare.
MikeinAlexandria is offline   Reply With Quote
Old 10-06-2009, 09:32 PM   #17 (permalink)
sleepe's Avatar
looks like you need a cayman
the Elise has no sound deadening relative to a typical sports car and offers no creature comforts...move on
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 10-06-2009, 09:58 PM   #18 (permalink)
Plain ol' Lotus-nut
khamai's Avatar
Have Rob Dietsch take a listen. He's on Lafayette in Santa Clara near 237. Take him for a ride and point out when you hear the issue.
Cheers,
Kiyoshi
life is better behind the wheel of a Lotus...
khamai is offline   Reply With Quote
Old 10-07-2009, 12:32 AM   #19 (permalink)
def
...ault
def's Avatar
I'd offer to help but I have a stage II exhaust so I don't know how much my car would help
Isn't your car under warranty? Could always stop by the local dealer...
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more SOLD after 1192 days and 22961 miles
def is offline   Reply With Quote
Old 10-08-2009, 09:36 AM   #20 (permalink)
Thanks for the updates everybody.
My updates:
1) It's actually more than one sound now that I've been investigating it. There's one sound from the engine/exhaust area and one from what sounds like the passenger side front. These sounds kinda blend when in motion.
2) sleepe, I don't need a Cayman. I have a desire to make my car work *right* - it's what I paid for. I'm concerned it's not working "right" and I want to get it fixed. Two trips to the dealer (two of them) didn't make the sound improve. This is NOT a sound a car should be making so it's not a matter of me "manning up" to the Lotus way of life.
3) yagobob, if you're bored this weekend, have a listen -- I'll drive to where you want to meet. PM me.
4) also may investigate Rob Dietsch, as mentioned.
As for today, I'm riding the Bonneville. Cheers.
