Brake Fluid Black - Can I Still Drive? - LotusTalk - The Lotus Cars Community
post #1 of 21 (permalink) Old 03-19-2008, 11:21 PM Thread Starter
uclacyc's Avatar
So my brake fluid is black. Should be the color of honey or something like it when new. I don't think that I'll be flushing it myself after reading TimMullen's Pressure Bleeding the Brakes post and realizing that 1) I have to buy all of this equipment like the pressurizer 2) I need new tires anyway (2/16" left) and most importantly, 3) this will take me like ten hours to figure out.
What are the consequences of driving around with black brake fluid, for another, oh, say 500-1,000 miles? I mean I know that the brakes can possibly fail, but can it really?
Rotor and pads are still good. I'm at 10,300 miles right now.
uclacyc is offline
post #2 of 21 (permalink) Old 03-20-2008, 04:02 AM
RoadDad's Avatar
You don't need a pressurizer, you can accomplish the same thing by pumping the brake pedal.
RoadDad is offline
post #3 of 21 (permalink) Old 03-20-2008, 04:16 AM
Chococar's Avatar
Change the brake fluid.
Chococar is offline
post #4 of 21 (permalink) Old 03-20-2008, 04:21 AM
fpitas's Avatar
If you just can't change it the right way, at least keep changing the fluid in the master cylinder until the fluid stays clean looking (i.e., change fluid, drive it a while, change it again when it looks nasty). That way you'll remove a lot of the entrained moisture that does the real damage.
Francis
2006 Chrome Orange Elise: LSD/TC, Nitron SAs with 425/650 springs, BWR 7/8" ("Hardcore") Front Bar, Eliseparts bumpsteer kit, VF Stage 2, 2bular Header + Sport Cat + 8x24 GT3 Muffler, ECU Tune by Jermaine, Smaay's fuel rail, ACT XT clutch, Saikou Michi dual catch can, Moroso pan, Manly's mount inserts & FF Engine Damper
2000 Black Integra Type R - DD: 231,000 miles!
fpitas is offline
post #5 of 21 (permalink) Old 03-20-2008, 04:58 AM
JimK's Avatar
depending on who you run with, you wont be allowed on the track with black brake fluid (and with good reason).
Spec Miata #73
Reynard F2000
various Hondas
JimK is offline
post #6 of 21 (permalink) Old 03-20-2008, 05:42 AM
Dave's Avatar
Simple brake bleeding procedure I've used from the other channel:
http://www.monkeytuner.com/forum/vie....php?f=4&t=575
Dave is offline
post #7 of 21 (permalink) Old 03-20-2008, 06:36 AM
www.theapexinn.com
kestrel74's Avatar
Absolutely !! If you don't know how to do it, take it to the dealer, but get it changed ! I change mine every year, but I track it quite a bit
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #8 of 21 (permalink) Old 03-20-2008, 06:43 AM
LotusUSA's Avatar
please bleed your brakes
"More power makes it fast on the straight, less weight makes it fast everywhere." - Colin Chapman
2006 BRITISH RACING GREEN EXIGE
2005 SAFFRON YELLOW ELISE (R.I.P.)
LotusUSA is offline
post #9 of 21 (permalink) Old 03-20-2008, 06:59 AM
EdHahn's Avatar
The reason why you don't want to run with black brake fluid is that the color indicates that there's probably a fair bit of contaminants and moisture that have been absorbed into the fluid. This is intentional (you wouldn't want moisture at the caliper end translating into a brake fluid that effectively boils at 100degC.)
However, if you let it deteriorate, the moisture can end up damaging metal components in your braking system through corrosion. This just means a lot of problems down the road.
ed
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline
post #10 of 21 (permalink) Old 03-20-2008, 08:04 AM
glb
glb's Avatar
The blackness is partly the rubber seals deteriorating, due to water in the system.
I recommend not pumping the brake pedal, esp on older cars, as you will be driving the seal into the unused, rough, corroded part of the m/cyl.
Do a search and you can see how I do it with an inexpensive Sears vacuum pump (hand operated) and their also inexpensive brake bleed kit.
The brk fluid that came with the car appears to be low quality. I use Castrol LMA, as does Tim.
Hope this helps.
Driving Tips-http://www.lotustalk.com/forums/f100...art-1-a-49665/
Moss Emergency Line-http://www.lotustalk.com/forums/f100...cy-line-36631/
Safely Piercing Wires-http://www.lotustalk.com/forums/f129...esting-106438/
Bleeding Brakes- http://www.lotustalk.com/forums/f101...-brakes-241138
glb is offline
post #11 of 21 (permalink) Old 03-20-2008, 08:19 AM
brakes have got to the most-overlooked maintenance item on this car. yet it's absolutely the most important system.
the price of having a brake system problem is pretty high.
fluid should be flushed regularly and changed at least on the suggested schedule. pads should be inspected monthly (if you're not tracking, else prior to each track day). take the wheels off. stick your head in there with a flashlight and inspect (NOT JUST GLANCE) all eight pads, leading and trailing edges, top and bottom edges. when the fluid is flushed, grab a micrometer and check the minimum thicknesses on the rotor. make sure the hub and caliper bolts are torqued properly. inpect the brake fluid lines for signs of damage. make sure the abs harnesses are being held in place by the clips.
there is a great deal of simple, yet required, maintenance on these cars. don't skimp.
ace10 is offline
post #12 of 21 (permalink) Old 03-20-2008, 08:26 AM
CosmosMpower's Avatar
Just get a friend and do it the traditional way. It took me 30 mins to do it my first time on the Elise, it's pretty much the same as any other car.
07 Porsche 911 GT3
10 BMW M3
03 BMW 330i ZHP
06 Canyon Red Elise- Katana SC (sold)
06 LRG Elise- (sold)
CosmosMpower is offline
post #13 of 21 (permalink) Old 03-20-2008, 08:59 AM
glb
glb's Avatar
C -
I beg to differ. Got the hardest pedal w/my method, which requires only 1 person and can't harm the m/cyl seal.
Don't forget to tap the caliper to release air bubbles...
glb is offline
post #14 of 21 (permalink) Old 03-20-2008, 09:05 AM
Blonde1's Avatar
Since no one else has mentioned it: be advised that brake fluid can/will damage paint. This doesn't mean that you need to be terrified of changing your own brake fluid, just that you'll want to exercise appropriate caution.
'05 CO Elise, Touring, Sport, Hardtop
When one door of happiness closes, another opens; but we often look so long at the closed door that we do not see the one which has opened for us.
Blonde1 is offline
post #15 of 21 (permalink) Old 03-20-2008, 10:55 AM
NCZ06's Avatar
Don't let the big write-up scare you. I didn't remove my wheels while bleeding and it saved a ton of time. It probably took about an hour start to finish taking my time.
2005 Lotus Elise - Ardent Red - Touring / HT / SS / Larini / Micromirror / Team Dynamics Pro Race 1.2s / Audiovox CCS100 Cruise Control
2012 Toyota Prius - Blizzard Pearl
NCZ06 is offline
post #16 of 21 (permalink) Old 03-20-2008, 11:13 AM
jkolb's Avatar
Just a note, but if you have introduced air into the system (like by cracking a fitting or changing a hose) at the front, you will have to remove the caliper from the hub and turn it upside down while you bleed it.
Jerry
2007 Laser Blue Exige S
1965 Elan (26r clone) vintage race car
2010 Audi S4
2003 Suburban
jkolb is offline
post #17 of 21 (permalink) Old 03-20-2008, 11:55 AM
raggedy1's Avatar
I seriously doubt your brakes are going to fail in the next 500 miles because your brake fluid is black in color at 10,300 miles. If it were me I wouldn't lose sleep over it as long as we're only talking street driving.
It's Delux son, Delux. It's not that hard.
http://itsdeluxson.com/
raggedy1 is offline
post #18 of 21 (permalink) Old 03-20-2008, 11:55 AM
TimMullen's Avatar
As other's have noted, you don't have to use the pressure bleeder - it just makes it easier and a one man operation. The pressure bleeder that I used costs less then $50 currently, and I've been using that one for nearly 20 years on various cars. The cost of paying a dealer to bleed your brakes will be more then the cost of the tools to do it yourself - although the dealer should be able to put the ABS into "bleed mode" to do 100% of the system.
But the old two man, pump the pedal method works just fine (I have to do it on one of my cars the the pressure bleeder won't work on).
As for "can you drive" with dirty fluid?" - of course you can, you were before you discovered that the fluid was dirty. But yes, you do need to get it flushed sooner rather than later. The longer you go, the greater the danger that water contamination will cause problems/damage in the calipers, etc. But things are not suddenly going to fail in the next 10 miles. As for the lowering of the boiling point (which starts occurring the moment that you put new fluid in the system), it also will be a gradual change, and not a sudden failure. But don't go out on the track with bad fluid because that will bring out any problems with the fluid rather quickly (as it stresses the capability of the fluid).
Bottom line is that you should flush the system as soon as you are reasonably able to - either DIY or at a shop. But don't loose sleep over it if you are delayed for a short time (unless of course you are going to do a track day). The best thing is to plan to flush the system at least yearly according to Lotus' maintenance schedule (more often for tracked cars).
94 Miata R Package - Black
TimMullen is offline
post #19 of 21 (permalink) Old 03-20-2008, 12:28 PM
JLSELISE's Avatar
Surprised no one has mentioned it yet, but a good trick is to use an old turkey baster to suck all the "bad" fluid you can out of the master cylinder before adding new fluid and doing the brake bleed--you want to minimize mixing the old with the new. (Also note that you should compress the bulb on the baster before you insert the tip in the old fluid--saves potentially making a mess .)
Joel
'67 S3 Elan dhc (owned since 1970)
'10 Evora (Carbon Grey/Charcoal)
'13 Volvo S60 T6 R-Design
JLSELISE is offline
post #20 of 21 (permalink) Old 03-20-2008, 12:49 PM
And lay newspaper/rags all over the fender etc since brake fluid is very bad for paint. Although the guy at the parts shop tried to convince me that the difference between DOT 3 and 4 is that 4 doesn't eat paint.
07 Porsche 911 GT3
10 BMW M3
03 BMW 330i ZHP
Human Verification
