#334
brake warning light on (dim)
My brake warning light is now on all the time, but dim. It is easily seen at night, but during the day it's very difficult to notice.
The bulb glows brightly when I pull up on the emergency brake, so it's still capable of a bright light. Anyone else have this symptom? Any ideas of cause? Thanks |
Mine flickers on high(er) load sweepers and turns (right or left), but does not light unless lever is pulled otherwise.
It is on my "fix this" list for the dealer at 7500 mile check.
Starlight Black - Biscuit / Turbo XS Intake / QS / RAC Monolites - SOLD |
lucas switches?
Storm Titanium, LSS, touring, hard top. my other car is a ...oh yeah i remember the other car...a spyder club111 member. i tried to buy a lower spot and become member #13 but was spurned! "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety" -benjamin franklin |
Check you brake fluid? The brake light usually always does double duty as the parking brake warning light, and the low brake fluid/brake failure warning light.
In addition, the Elise, the clutch master cylinder shares the fluid reservoir with the brake master cylinder.
#7 (permalink) |
I cannot speak for Choco, but my fluid is fine (just checked). Level is just below the rounded top portion of the resevoir, well above either of the minimum lines.
#8 (permalink) |
eliseaholic!
Check the brake actuator switch which is on the handbrake, it can be adjusted, perhaps its just not set quite right so it's slightly on?
Chris
Chris Club111 #3 06 Solar yellow/Touring/Traction Ctrl/Blk Whl Pkg/Strshld
#9 (permalink) |
Hello Choco,
I am experiencing the same problem on my three weeks old elise. I already checked the brake fluid level including the sender and everything is ok. If you do a test on the sender switch in the canister cap you will notice that when the sender indicates that the brake fluid is low the brake light will be as bright as when the lever is up. I really don't know what seems to be the problem. If you find out please let me know since where I live there is no representative to give me warranty. Thanks, Tito |
#10 (permalink) |
#334
After some thought experiments, I've decided that it's probably a switch (level, handbrake, etc) that has a low resistance to ground (e.g., partial short). I'll work on it over the next couple of days and see if my guess is right.
#12 (permalink) |
LOG29 Co-chairman
The same thing happened to mine so I took it to LOA. They said that the sensor on the brake canister cap had a short, causing the car to think that it was out of brake fluid and thus light the warning light. They had to order a replacement cap from Hethel.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter LOG29 - http://www.log29.org President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
#15 (permalink) |
#334
Dim brake warning light problem solved!
The dim brake warning light returned after a few weeks (of course). I pulled one wire from the brake fluid level sensor, and the dim light went away. I could make it come and go this way with either wire, so I decided that I had found the problem.
I pulled off the rubber cap covering the sensor, exposing a very simple switch. I saw some gunk between the two contacts, so I cleaned it off with a little plastic scraper. Problem solved! See the picture below. |
#16 (permalink) |
my god i love this board!!! just happened to me on the drive home...quick search, wiped off switch with a paper towel nothing....blew on the switch a few times and gone!!!
thx guys
You can't rationalize cars like these, they're not something you buy with your head, you buy them with your heart because you love them and who can explain love. All I know is I love my lil elise more then I like any other car... |
#18 (permalink) |
yea...i just washed my car this morning, but i've washed my car 6 times before without this prob
#19 (permalink) |
This happend to me a yr ago when the car was 3 weeks old
Dealer fixed and blamed me for dropping something on hand brake ?!?!?!?!
I never dropped anything on it. They fixed, no light. Now for the past month light was back on. I was avoiding it till next visit to dealer. Now I'll try to clean it & see. Thanks Bruce ![]() |
#20 (permalink) |
phantom brake light
The instrument brake warning light was now on all the time, but dim. It was easily seen at night, but during the day it too was very difficult to notice.
The bulb glowed brightly when I pulled up on the emergency brake, so it was still capable of a bright light. The car sat over night and the dim indicator light has vanished. Will the saga continue.....will the light return again....I know one thing, if it does, this forum will come up with the answer just as I was able to pull up these suggestions. Thanks all Steve
Proud member of COM |
