Old 08-10-2007, 03:11 PM   #1 (permalink)
Daedelous's Avatar
Brakes Squealing. How Safe?
About 30% of the time my front brakes (maybe just the front right one) are squealing. Sometimes when I have the brake depressed, sometimes when I don't. If it's the former, letting off the brake stops the sound. If it's the latter, depressing the brake stops the sound. I don't know anything about brakes, but my front ones look like the pads are about 1/16" of an inch thicker than what I'm assuming is the rotor.
I've already ordered new pads, but there is a once-in-a-lifetime cruise opportunity lasting maybe over an hour this weekend, and I'd like to go. I haven't experienced any noticeable loss in braking power and my wheels haven't been squealing like this for more than a couple hours (though it used to happen maybe once every 10 drives).
How safe is it for me (and my rotors) to take it for this one final spin before the pads arrive?
Adam
2006 Lotus Elise - Chrome Orange
Touring Pack
Track Pack
Limited Slip/Traction Control
Hardtop
Stage 2 Exhaust
Daedelous is offline   Reply With Quote
Old 08-10-2007, 03:12 PM   #2 (permalink)
It's a Lotus
LARRY's Avatar
How many miles on your pads?
I underestimated my pads and just missed. Pads hit rotors, rotors need to be replaced.
Can't tell by your description of the sound....
Mine sounded like a bad grinding sound.....not a squeal.
I would get them checked-------NOW.
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats.
LARRY is online now   Reply With Quote
Old 08-10-2007, 03:16 PM   #3 (permalink)
Randy Chase's Avatar
Images: 761
I don't think the squealing is that related to pads being worn (as it is on cars with squealing indicators). The important thing is that you should know how much brake pads you have left and periodically check them.
Once you learn how, it is easy. And that is the thing to do. If you have enough pad, no worries. If not, then that is bad.
http://www.facebook.com/randychase
1991 Toyota MR2. AutoX Beast
2006 Noble M400. Track weapon.
2009 Rossion Q1. Monaco Orange. Canyon Carver.
Lexus GX-470 tow vehicle. On Order: Lotus Evora Next: McLaren MP4-12C
Old 08-10-2007, 03:16 PM   #4 (permalink)
It's a Lotus
LARRY's Avatar
What he said. Yeah!
Old 08-10-2007, 03:19 PM   #5 (permalink)
-30-
ace10's Avatar
Images: 35
you REALLY need to do a good visual inspection. leading and trailing edges, inside pad and outside pad, both sides. an estimated 1/16th of an inch is NOTHING. personally, there's no way i'd take the chance with negligible pad material.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.
08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C
The Red Pill Ignore Me *Be sure too save your IL before browsing away
ace10 is offline   Reply With Quote
Old 08-10-2007, 03:19 PM   #6 (permalink)
It's a Lotus
LARRY's Avatar
What he said, too...
Old 08-10-2007, 03:23 PM   #7 (permalink)
It's a Lotus
LARRY's Avatar
Get them looked at right away. Save your rotors.
Or, ignore them and spend ALOT more money.
Old 08-10-2007, 04:47 PM   #8 (permalink)
TimMullen's Avatar
Images: 19
Squealing is not a bad thing - just annoying.
Grinding brakes indicate that the pads have worn out and are destroying the rotors.
Which sound do you have?
Grinding is a low "growling" sound - metal scraping against metal. It often happens all the time, and gets worse when you push on the brake pedal.
Squealing is a high pitched sound - kind of a "screaming". Sometimes you get a bit of squealing as you drive without applying the brakes. Sometimes you get the squeal when you lightly apply the brakes. And sometimes (usually) when you push the brakes very hard, the squealing goes away.
Squealing is nothing to worry about.
It happens because of the way that the surface of the pad has "glazed". One way to get rid of the squeal is to do several stops from fairly high speed while stopping hard. This will "bed in" the brake pads by heating them to a higher temperature and often gets rid of the squealing. This is why the sounds goes away when you apply the brakes hard, you are getting them hot.
The other cause of the squeal can be the pads "fluttering" (vibrating) in the brake calipers. The cure for this is to remove the pads, and apply brake grease to the parts of the pads where the metal of the pad contacts the calipers (don't get any grease on the surface of the pads!). You also apply the brake grease to the back of the pads where the pad contacts the piston or outside of the caliper in the case of the rear calipers. The grease lubricates the pads and dampens the fluttering.
Auto manufacturers spend a lot of money attempting to minimize (or eliminate) the squealing sounds. Unfortunately, the cure is usually to make pads that don't last as long, and don't work as well. Performance pads (as used on the Elise) tend to skip the "quietness" capability in trade for the performance capability.
Figure out if you have the "squealing" or the "grinding". If it squealing, try to re-bed the brakes. If it's grinding, it's already too late, and you need new pads and rotors.
Another
94 Miata R Package - Black
TimMullen is online now   Reply With Quote
Old 08-10-2007, 04:49 PM   #9 (permalink)
Chris Mackey's Avatar
Do you have the touring brakes? They don't squeal
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 08-10-2007, 05:35 PM   #10 (permalink)
TimMullen's Avatar
Images: 19
There always has to be one...
Old 08-10-2007, 05:40 PM   #11 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
Has anyone (or can someone) post a pictorial how to for brake pad inspection. I look at mine everytime I change my wheels (before every event) but I must admit, I don't know for sure what I'm looking at/for.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 08-10-2007, 07:14 PM   #12 (permalink)
choi0706's Avatar
thickness of pad material.. eyeball it..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 08-10-2007, 09:19 PM   #13 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
If somebody could post up a picture from the service manual please... Section JJ, Page 6. For some reason my scanner is screwed up.
Oh wait a second. Here just look at this PDF page. It's got a picture.
The rotor is the big circular thing with some rows of holes drilled through it.
The caliper is the thing with LOTUS writen on it and a rubber brake hydrolic hose connected to it.
The pads are fit into place between the caliper pistons and the rotor surface. They have some friction material, and a metal backing plate. You want to check the thickness of the friction material. Is it at least as thick as the backing plate? Then you're good to drive another week before you CHECK AGAIN.
Well, when they're brand new you don't need to check every week of course. But if they get that low you should have your new set on it's way to you.
Old 08-10-2007, 11:06 PM   #14 (permalink)
Daedelous's Avatar
Squealing. So I guess I'm probably OK for at least this one drive.
Adam
Touring Pack
Track Pack
Hardtop
Stage 2 Exhaust
Old 08-11-2007, 08:45 AM   #15 (permalink)
xtn
xtn's Avatar
Friggin CHECK them.
You should KNOW you're okay for at least this one drive. Why would people just drive around willy nilly "guessing" at their braking capability?
Old 08-11-2007, 08:46 AM   #16 (permalink)
-30-
ace10's Avatar
Images: 35
Originally Posted by xtn
Friggin CHECK them.
+1
Old 08-11-2007, 07:29 PM   #17 (permalink)
exarkun1178's Avatar
hi.
so last week my right front was squeeking a lot! so because i did not want messed up rotors, i went out and got pads the next dat and changed them that afternoon(really easy) anyway, here i am a week later and the front right istarted squeeking again.
the old pads did have plenty of matirial on them after taking a look and comparing them to the new ones.
the engine light is on again anyway, so ive got to take it in. i hope hrm knows whats wrong with it.
maybe you have the same problem?! ill let you know how it turns out later in the week.
[Ovarian Odorist] 11:12 pm: why did you ever get into your business rob...you have such great potential in the adult porn industry..
exarkun1178 is offline   Reply With Quote
