#61 (permalink) |
2007 Exige S
Front clam removal is at most 1 hr (probably less). The $1900 is just greed and toss in the fact you're a Lotus owner and hence have money (Porsche, BMW, Ferrari, etc. they all bend you over).
I honestly don't think you'll make any legal grounds using the "safety issue" angle. I think you'd have more potential success if you find out if the TSB (which this is) even requires a warranty. Some TSB MUST be covered regardless of in/out of warranty or if they present a safety issue. Contact Lotus direct not a dealer, don't spend the money on a lawyer either.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#62 (permalink) |
OSX Black hat
I'd talk to lotus more about it, rather than having the NHTSA force a recall, that'd be bad.
#63 (permalink) |
I'm doing the resistor job right now on my car that has been out of warranty 3 months. It's not really that hard, just tedious. My problem is that the threads on the condenser got buggered just by unscrewing the fittings. It's like they were over torqued by the factory; they were seriously tight, and there's no indication of corrosion between the steel nut and aluminum fitting. It so far has cost the price of the resistor replacement kit, a couple rethreading dies, and an aluminum repair welding rod kit, ~$300 total. I hope to be back on the road this weekend. At least partial reimbursement from Lotus would make me happy.
Martin 05 KG Elise |
#64 (permalink) |
This may sound like a silly question, but has anyone tried bypassing the corroded resister pack and reinstalling a new one under the dash? I would think this could all be done without even having to touch the one up front. Just snip the appropriate fan and power wires at the switch, and install resisters. There would be plenty of room to mount the pack under the dash AND there would be little chance of it corroding there.
05 Saffrron Yellow, Sport, Touring, Star Shield, Larini w/ sport cat, Katana Supercharged, SSR Comps with RE01R's. |
#65 (permalink) | |
Alarmed & Dangerous
Can't be bypassed without accessing the existing one. The reason is that the wire that runs between the resistor pack and the blower is a very short wire that is inaccessible. I had thought of this option myself and then discovered the problem
.Quote:
#66 (permalink) |
My Exige, which I am trying to sell, has this problem. Its definitely the resistor pack. The same trick as posted a couple pages back in this thread, dumping a bucket of water down the front of the car, used to work for me to get it working again
![]() Anyway, I've had a number of guys interested in the car but bugging out because they perceive that the cost of this repair is going to be extreme. If I don't find any takers soon, I think I am going to try to trade in as is. If that doesn't work, then I think I am going to have to do the job myself. Getting the car to/from a dealer is not going to work, at least not anytime in the near future, with my schedule a new house and a baby. Someone other than myself, with different life circumstances / easier access to the dealer, could probably have this taken care of pretty easily. I've got a ton of tools. What I'm unsure of is, do the AC lines have to be physically removed, or can they simply be pushed out of the way? I do not own a device for "recovering the refrigerant" What is involved in this step? Can the shadetree mechanic rent a machine without an EPA license? And following the repair, how do you reload the refrigerant into the AC system? This is really the only part of this repair that concerns me. The rest does not appear to be very difficult. I replaced the subframe bushings once in an old BMW by myself, this can't possibly be harder than that ![]()
2006 Solar Yellow Exige Touring Pack, Track Pack, Starshield |
#68 (permalink) |
Alarmed & Dangerous
The clam has to be removed as well as most of the nose located HVAC system. The blower motor has to be removed to access the resistor pack on the underside. This is a photo of the resistor pack & blower.
Cheers, Michael
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 06-20-2009 at 04:05 PM. |
#69 (permalink) |
Unattractive Nuisance
viper,
You, sir, are a treasured resource here. And, fast: I never get to answer ![]() Really, tho, terrific work. Thank you! ![]()
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. 6. "A bore is a man who deprives you of solitude without providing you with company." - Gian Vincenzo Gravina |
#70 (permalink) |
Alarmed & Dangerous
I just have an addiction for knowledge, maybe I need a 12 step program
Anyway, thank you for your very kind words, and say hello to Succasunna for me.Cheers, Michael
#71 (permalink) |
Thanks for the response! Hmmm...I'm not too afraid of the disassembly and reassembly, but I've never touched refrigerant before and that part scares me :-) If most of the hvac system has to be removed, then I suppose there is no avoiding dealing with the refrigerant. Is that as simple as just buying a device to do it?
#72 (permalink) | |
Alarmed & Dangerous
I believe only a licensed tech can do it, but I may be wrong.
michael Quote:
#73 (permalink) |
So here's my question, if it requires a licensed tech to do it, how are you other guys doing this repair on your own???
#74 (permalink) |
Anyone can buy the equipment and supplies to recharge an AC system (with the exception of old style R-12 "Freon"). The catch is that it is not legal to vent the AC system to the atmosphere (you have to capture it and recycle the gases). I've got all the gear to charge up a system because I needed to repair a broken system and it was cheaper to buy everything than it was to pay someone to to the work - but the system had already leaked the gases...
#75 (permalink) |
I see Harbor Freight has a vacuum pump and manifold gauges on sale pretty cheap. What could I connect the vacuum pump to to collect the gases? Could I just run a tube into a soda bottle or something?
#76 (permalink) |
Hydrocarbons Rule
My blower fan also completely quit all at once a few days ago... I tried looking for the resistor pack part number on Lotus Garage and couldn't find it. However I did find this... Is part #6 the correct one?
Lotus Garage - Horn, Inertia Switch, Fuses & Relays
#77 (permalink) | |
Live from the Bubble Room
Lotus Garage - AC Interior Blower Motor
"Never leave well enough alone" Raymond Loewy |
#78 (permalink) | |
Hydrocarbons Rule
#79 (permalink) | |
Alarmed & Dangerous
The resistor pack needs to be relocated to a less wet location to avoid a repeat.
Michael Quote:
#80 (permalink) | |
Correct, it is part 02 in the link below. This is the resisitor kit that also relocates the Resistor at the same time.
I bought mine from Elise Shop.. Heater fan resistor replacement package (Elise S2) [A120P0148S] - €104.99 : Elise Shop, Performance parts for your Lotus Elise Their website actually shows what the kit looks like.... Quote:
