Old 09-30-2008, 06:50 PM   #1 (permalink)
MidasHands's Avatar
A/C and Heater Don't work after running through puddle
Another Lotus owner on this board ran through a large puddle of water over the weekend and his a/c and heater stopped working. The blue light for the a/c does not even go on.
Any ideas of what he can check? Fuses?
- Mike
2006 KG Elise, Magnolia Interior
MidasHands is offline   Reply With Quote
Old 09-30-2008, 06:58 PM   #2 (permalink)
Elise...Best Daily Driver
British_Marques's Avatar
Okay, What you need to do is take a 20amp fuse with you as you poke your head upside down in the passenger seat and your feet hanging on top of the bow cover at the top of your car. look under the dash, you will find a triple block of 20a fuses and more than likely the center fuse is blown. simply pull it and replace with the new one and you should be fine. There are two set of those fuses under there. This is where they are located for the HVAC system. You should be fine except for the crick in your neck from standing on your head.
2005 Elise, Starlight Black/Red, stage II exhaust, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and custom wheels that favor the M250, no understeer and a variety of the simple mods.
British_Marques is offline   Reply With Quote
Old 09-30-2008, 06:59 PM   #3 (permalink)
MidasHands's Avatar
Thanks I'll check that!
- Mike
Old 09-30-2008, 07:05 PM   #4 (permalink)
2007 Phantom Black Elise
Phil S's Avatar
My new Elise got wet for the first time this weekend. The A/C stopped working similar to the post above. It did come back to life an hour later.
Whats with that???
Phil S is online now   Reply With Quote
Old 09-30-2008, 07:11 PM   #5 (permalink)
Gremlins...
Old 09-30-2008, 07:26 PM   #6 (permalink)
Genius!
qball's Avatar
Images: 2
It's British.
qball is offline   Reply With Quote
Old 09-30-2008, 08:13 PM   #7 (permalink)
MidasHands's Avatar
His has been out for a couple days so I don't think it is going to just come back on.
He is going to check it tomorrow in the day light.
- Mike
Old 09-30-2008, 08:25 PM   #8 (permalink)
Genius!
qball's Avatar
Images: 2
Old 09-30-2008, 09:17 PM   #9 (permalink)
peregrinus caelum
...m...'s Avatar
...there's a service recall modification to drill drainage holes underneath the HVAC assembly, barring which it tends to short out or corrode due to standing moisture - my previous circuit died thusly...
...67,000 miles and aging beautifully...
Old 10-01-2008, 07:38 AM   #10 (permalink)
06 SY Exige
LordZ's Avatar
I would strongly suggest anyone without the holes drilled that drive in the rain or even wash their car to get it done. That circuit that gets shorted out requires a front clam removal to replace if I'm not mistaken.
LordZ is offline   Reply With Quote
Old 10-01-2008, 03:33 PM   #11 (permalink)
macdady2424's Avatar
Remember to take your shoes off 1st. Although, I think in my avatar my shoes are on, but you can leave scuff marks.
225 TTQC & 05 Elise
macdady2424 is offline   Reply With Quote
Old 10-01-2008, 04:27 PM   #12 (permalink)
Ex-Brit
TheViper's Avatar
It's the blower motor resistor pack corroding/ shorting out.
A/C Improvement Modifications
http://www.lotustalk.com/forums/f3/e...ent-mod-59938/
1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat.
2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up.
3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose.
Old 10-03-2008, 02:46 AM   #13 (permalink)
Iben's Avatar
Hi
Yes it is (see picture).
I'm just finished with this job.
Iben is offline   Reply With Quote
Old 10-11-2008, 06:14 AM   #14 (permalink)
the devil's advocate...
Originally Posted by Iben View Post
Hi
iben, is the bottom pic the actual lotus replacement part or did you build that yourself?
rob13572468 is offline   Reply With Quote
Old 10-11-2008, 07:18 AM   #15 (permalink)
can it kill me?
jwood's Avatar
Images: 5
My 06 exige is in the shop right now getting this replaced. I tried the fuse with no luck. Apparently they are replacing the same thing iben has done. So far it has been 3 days! Now I get to drive a vw passat loaner! I miss my car.
jwood is offline   Reply With Quote
Old 10-16-2008, 08:19 PM   #16 (permalink)
well it turns out that the $150 dollar resistor pack replacement is actually $10 worth of resistors...
HTML code is On
