A/C and Heater Don't work after running through puddle
Another Lotus owner on this board ran through a large puddle of water over the weekend and his a/c and heater stopped working. The blue light for the a/c does not even go on.
Any ideas of what he can check? Fuses?
- Mike 2006 KG Elise, Magnolia Interior |
Elise...Best Daily Driver
Okay, What you need to do is take a 20amp fuse with you as you poke your head upside down in the passenger seat and your feet hanging on top of the bow cover at the top of your car. look under the dash, you will find a triple block of 20a fuses and more than likely the center fuse is blown. simply pull it and replace with the new one and you should be fine. There are two set of those fuses under there. This is where they are located for the HVAC system. You should be fine except for the crick in your neck from standing on your head.
2005 Elise, Starlight Black/Red, Modified tilting clam, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and Cup Wheels & Tires. |
Gremlins...
#7 (permalink) |
His has been out for a couple days so I don't think it is going to just come back on.
He is going to check it tomorrow in the day light.
#9 (permalink) |
Denuo Volatilis
...there's a service recall modification to drill drainage holes underneath the HVAC assembly, barring which it tends to short out or corrode due to standing moisture - my previous circuit died thusly...
2005 Federal Elise | Touring | Storm Titanium ...73,000 miles and aging beautifully... 2000 New Beetle | Turbo | Reflex Silver ...107,000 miles of steadfast service... |
#10 (permalink) |
06 S280
I would strongly suggest anyone without the holes drilled that drive in the rain or even wash their car to get it done. That circuit that gets shorted out requires a front clam removal to replace if I'm not mistaken.
#12 (permalink) |
Alarmed & Dangerous
It's the blower motor resistor pack corroding/ shorting out.
#17 (permalink) |
FYI... just had this happen, the dealer said it would be a grand to replace the resistor pack. For sh*ts & giggles I checked the fuse and that's what it was. Saved a grand, and I am one very happy dude. ;-)
(yes I know I should've checked the fuse first, but it makes for a better story this way) |
#18 (permalink) |
The Azteks are coming!
anyone know if one can have this replaced before any issues happen on an 07?
or does the 07 already have the fix in place?
The difference between ordinary and extraordinary is that little extra. F The System - ChuforiaGraffix.com SweetDaddyDelicious(at)hotmail(dot)com |
#19 (permalink) |
I think mine is shorted out. During the Summer, I was on my way home and got caught in a downpour. The AC stopped working. The fan would not go on... nothing. Well now the fan works, but I have no heat. I haven't tried the A/C because there is no need for it now. If this IS the problem can someone explain how to replace it?
05 Saffrron Yellow, Sport, Touring, Star Shield, Larini w/ sport cat, Katana Supercharged, SSR Comps with RE01R's. |
#20 (permalink) | |
Alarmed & Dangerous
If the blower fan is working but you have no heat then it sounds like one or both of the two flap valves in the climate box are not diverting the air flow. You can see them by taking off the large flexible duct that comes out of the top, looking down while getting someone to operate the temperature control.
